Thread: Strange Moaning Noise 02 GTP
Results 1 to 20 of 28
  1. #1 Strange Moaning Noise 02 GTP
    SE Level Member 02GTP 91WS6's Avatar
    Sep 2017
    NE Ohio
    Hey all,
    I have a strange noise coming from my 02 GTP. It comes on at operating temp and after shutoff it fades away after a couple of seconds. I assumed it was a pulley issue but the sound stays on for a couple seconds after shutoff, so I thought maybe it was the power steering pump. I'm at a loss right now, more details in the video attached. Let me know what you guys think.
    https://www.youtube.com/watch?v=7TIXXubSHSY
    2002 GTP coupe -- 2.9 pulley -- 2.25" IC -- N* TB -- Polished Gen V SC -- and more
    1991 Trans Am WS6 -- 350 crate -- shift kit
    2006 G6 GT Coupe -- Daily Driver
  2. #2 Re: Strange Moaning Noise 02 GTP
    take both belts off and start it, if the sound is gone its something the belt turns, alt, p/s w/p a/c. hand spin em all till you find one that dont spin as free. or has a wobble. idlers and tensioners too.
  3. #3 Re: Strange Moaning Noise 02 GTP
    Sep 2017
    NE Ohio
    Will do, thank you.
  4. #4 Re: Strange Moaning Noise 02 GTP
    if you take the oil cap off and it stops the pcv is blocked. heard them make sound slike that before.
    you got a intercooler under the blower?
  5. #5 Re: Strange Moaning Noise 02 GTP
    Oct 2014
    portland oregon
    my bet is the pcv also.. the pullies stop and sound continues like air.. If your air filter is a KN gona have to oil it. it looks like a unoiled filter.. the Bay is nice and tidy tho. Sweet car
  6. #6 Re: Strange Moaning Noise 02 GTP
    hangover park IL
    Blocked fresh air passage. Either at the tb gasket or sc gasket....fairly common if excessive rtv is used
    ~James~ Psychotic Gearhead
  7. #7 Re: Strange Moaning Noise 02 GTP
    Sep 2017
    NE Ohio
    Scotty, no I don't, but I'll check the pcv with the oil cap, thanks! Turbocharged400sbc, I had the sc off last weekend and the sound is away from the TB, but that was checked. It does have two spacers between the LIM and SC though, is that normal or could that cause an issue? Still not 100% familiar with these cars. Wowitsfast, thanks man, the previous owner definitely was meticulous and I plan on carrying it on, thanks for the input.
  8. #8 Re: Strange Moaning Noise 02 GTP
    if that sound goes away oil cap off, the p/o either got to much rtv on there and blocked the pcv holes up, or the spacer is blocking the pcv holes, or one of them.
    once the cap is off if you put your hand over the vc hole you'll feel it sucking air in. another member had this issue and it blew the front main seal off on him.
    this thread covers how to deal with this issue if your spacers cover the pcv holes. lots of pics. always good.
    http://www.grandprixforums.net/threa...cover-breather!
    pb fix thread if you dont have this yet. http://www.grandprixforums.net/threa...ck+photobucket
  9. #9 Re: Strange Moaning Noise 02 GTP
    posted the how to, has pics. ^^^^^^^
  10. #10 Re: Strange Moaning Noise 02 GTP
    http://www.grandprixforums.net/threa...en-five-gen-5) this thread show the gen 5 pcv nipple and evap port int he gen 5, gen 3 dont have this. so you need to make it hook up right.
  11. #11 Re: Strange Moaning Noise 02 GTP
    Sep 2017
    NE Ohio
    Sorry for the late reply guys, I was away at school. So I removed the oil cap, sound disappeared. I got a replacement PCV valve and put it in, car sounded and ran fine until operating temp, then the original sound came back along with a terrible squeak. I'm assuming I either put the PCV in incorrectly, or I got the wrong pcv valve.
    I realized after testing it, but I have a Gen V SC. Does it use a different pcv than a stock 02 GTP? I just picked one out based on my year and model.
  12. #12 Re: Strange Moaning Noise 02 GTP
    HUDSON
    Was the o-ring in place on the pcv valve?
  13. #13 Re: Strange Moaning Noise 02 GTP
    Sep 2017
    NE Ohio
    Quote Originally Posted by QUICKSILVER462 View Post
    Yes, O ring was in place and intact, I used it for the new one and I just removed it, still in place on the new one
    Sent from my XT1650 using Tapatalk
  14. #14 Re: Strange Moaning Noise 02 GTP
    you need to take the sc off and make sure its pcv holes are clear of rtv or anything else.
  15. #15 Re: Strange Moaning Noise 02 GTP
    Sep 2017
    NE Ohio
    I had it off a couple of weeks ago for the LIM gasket, it was clear. I put the old pcv valve back in for kicks and giggles and the squealing sound stopped, with the original sound still there. The pcv valves were noticeably different where the spring rests on the valve itself, and it did not stick on the new one as well. Is that an issue?
  16. #16 Re: Strange Moaning Noise 02 GTP
    id still take it off and re check the pcv and the two small holes in the blower. only time we hear that sound is a blocked off pcv passage, it can be just one of the two also.
    we hear this when a zzp ic is installed. for what ever reason their core blocks off the rad side port.
  17. #17 Strange Moaning Noise 02 GTP
    Quincy, Mass
    Did you use a gasket on the pcv cover?
    Maybe you got a bad valve, get another one at the store and try it out.
    No more GP 04 Impala SS Indy:
  18. #18 Re: Strange Moaning Noise 02 GTP
    Sep 2017
    NE Ohio
    Quote Originally Posted by Swiggles View Post
    Did you use a gasket one the pcv cover?
    I just double checked not too long ago and felt like an idiot. The p/o didn't have a gasket for it, could that be the only thing?
    Again, I have a gen v sc, and I've seen a lot of write ups about a custom pcv system with them. Is that feasible?
    I'm also seeing that IC cars can get away with a breather on the valve cover?
    Thanks for helping me out guys, I'm definitely in uncharted **** for me lol
  19. #19 Re: Strange Moaning Noise 02 GTP
    http://www.grandprixforums.net/threa...cover-breather! this is the ic blocked the pcv fix.
  20. #20 Re: Strange Moaning Noise 02 GTP
    Sep 2017
    NE Ohio
    Interesting fix. I saw this picture sseilmnop posted before seeing your link: http://www.grandprixforums.net/threa...tion-about-pcv
    I think that picture might be the one missing in the link you sent me. Vac line from Oil neck to Drilled out TB nipple? And can it be done any way without drilling, as long as it's between butterfly and sensor?
  1. Strange noise
    By LEVELX in forum Introductions/Noob Questions
    Last Post: 09-25-2017, 03:45 AM
  2. Strange Rattle Noise?
    By 04noobprix in forum General Grand Prix Discussion
    Last Post: 05-04-2016, 10:07 PM
  3. Strange noise
    By TheDarkAngel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2014, 06:20 AM
  4. Strange noise when reversing. What could it be?
    By giannim in forum General Grand Prix Discussion
    Last Post: 09-30-2013, 07:18 AM
  5. Strange engine noise
    By alvaradoguy2002 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-19-2012, 11:29 PM
