Thread: 04+ Interior Swap - Seat Belts
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: 04+ Interior Swap - Seat Belts
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by green97 View Post
    Dis you swap the rear seat at all? Interested in how to get the child seat loops that go in between the top and bottom half of the rear seat. Looked at one in the junkyard and it appears it is part of the metal bracket behind the seats in the rear.
    The child seat clips are built into the 04+ rear seat, when you swap the rear in you will have them.
  2. #22 Re: 04+ Interior Swap - Seat Belts
    SE Level Member green97's Avatar
    Jul 2011
    Eastern Idaho
    Quote Originally Posted by 231FUN View Post
    I was looking at an 05 in the junkyard last weekend and I couldn't get the lower cushion to release in order to look. It appeared that there was a metal piece spanning the back at the bottom of the upper cushion but couldn't tell if it was part of the cushion or something that bolted on the body separate from the cushion.
  3. #23 Re: 04+ Interior Swap - Seat Belts
    Jul 2010
    Coquitlam,BC,Canada
    FYI, the 05 GTP rear seat I have has no provisions for child-seat restraint.
    Hmm, looking at some other peoples pictures, these metal thingies must be what you guys are talking about; I thought they were ties downs for when the seat was
    folded down.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #24 Re: 04+ Interior Swap - Seat Belts
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    The rear seat is kinda weird, it's got two pull handles under the thickest parts of the foam, those sometimes work. Lol mine works on the passenger side, but the driver's side refuses to release 85% of the time.
    The bottom cushion is literally just a cushion, and the back of the seat is permanently attached to that frame so it can fold down. Its 3 or 5 18mm bolts and a bunch of 10mm bolts to remove the rear seat frame, which is a bish if you accidentally forget a bolt and start pulling and bend it out of shape. Lol
    And Bronco Boy is correct, there is no child seat restraints on most of the 04+ seats, it wasn't standard equipment.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  5. #25 Re: 04+ Interior Swap - Seat Belts
    Jul 2010
    Coquitlam,BC,Canada
    Lots of install/comparison images here: http://gtpworld.net/viewtopic.php?t=3636
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #26 Re: 04+ Interior Swap - Seat Belts
    Jul 2011
    Eastern Idaho
    Quote Originally Posted by Bronco Boy View Post
    folded down.....
    This...
    http://www.carseat.org/Legal/622_Latch.htm
    Sorry to clutter your thread. It looks like they started installing them in 2003. Just found the info on them in a 2003 owner's manual but not for my 2002. They are mostly invisible, you have to poke your fingers between the cushions to feel them. Most cars that have them will have little buttons with a picture so you know where to poke your fingers in. Those white buttons on yours are what I am referring to.
  7. #27 Re: 04+ Interior Swap - Seat Belts
    Jul 2010
    Coquitlam,BC,Canada
    Ah, that makes more sense. Look like something you would/could mount to the floor under the seat.
    As long as we keep uncovering little things like how to mount seat belts and baby seats, it's all good.
    If this thread prevents one person from having to remove the front seats 3 times to get the seatbelts mounted correctly, I've done my job. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. 04+ interior/seat swap in 97-03
    By Tyarne15 in forum Visual/Body Modifications
    Last Post: 05-28-2015, 03:51 PM
  2. Seat belts
    By KawaFord in forum Off Topic Discussion
    Last Post: 07-04-2010, 12:18 AM
