We bought this GXP last week. All is great with the car except for some tire noise, which the previous owner alerted us about. The tires are less than 1/2 worn, so we'll have to put up with this for some time.
My concern is the ABS/Stability System/Traction Control. The warning light came on yesterday. I had the codes checked by Advance Auto Parts and deterimined the problem was the right front speed sensor. I think I've found the problem where the wire harness passes under the front of the engine. The insulation rubbed off some of the wires against a metal wire holder. I moved the harness a little so the bare portion is not shorting to the wire holder and the problem went away. I plan to fix the insulation problem and protect the wires from the holder as a permanent fix.
The code reader showed a total of 7 codes. One was the speed sensor. Another was the oil pressure sensor. Another was a communication problem between the engine and computer. I can't remember the rest of the codes. The engine runs fine and the "engine" light is not on.
Can I reset these by disconnecting the battery?
Also, I've noticed an intermittent problem when stopping that the car shudders as though the transmission did not downshift. The brakes are smooth--no shudder there. Is this a serious symptom with the 460LE transmission?
