Thread: Pinched a wire or harness, how screwed am I?
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Pinched a wire or harness, how screwed am I?
    Jun 2017
    In a state of constant panic
    Got all 3 bolts in along with the mount, but now I'm having one hell of a time lowering the mount down into the holes on the subframe.
  2. #22 Re: Pinched a wire or harness, how screwed am I?
    Jun 2017
    Got it. Gave up on the floor jack due to it pulling the engine forward or moving it back towards the firewall. Broke the scissor jack out of the trunk and with it and a prybar I'm back in business.
  3. #23 Re: Pinched a wire or harness, how screwed am I?
    Jun 2017
    I replaced a bunch of stuff today (struts, tie rods, etc) and noticed a bulge in the subframe directly under the poly mount. It isn't bent but it sure looks like the rounded bottom of the mount has distorted the metal on the subframe.
    Anything I need to be concerned with?
  4. #24 Re: Pinched a wire or harness, how screwed am I?
    Mar 2017
    Internet
    Picture would be very helpful. Because.. how do you bend a subframe?
  5. #25 Re: Pinched a wire or harness, how screwed am I?
    Jun 2017
    I'll get pics asap.
  6. #26 Re: Pinched a wire or harness, how screwed am I?
    Jun 2017
    Looks like the buldge was caused by the deepwell 10mm socket I dropped in the cutout for the motor mount. I dropped a bolt behind the balancer and used the extension and 10mm to push it out and the socket fell off.
    It rolled all the way to the rear of the subframe not currently sits wedged between the lower mount but and the subframe itself. Probably doesn't help that I used a 3ft breaker bar to tighten the nuts as tight as humanly possible.
  7. #27 Re: Pinched a wire or harness, how screwed am I?
    Jun 2017
    I got a closer look at the bulge today and I’m a bit proud to be honest. The shape indicates the subframe was bent from launching, not the socket. I’ve got pics but the mobile site doesn’t have an imbed option.
  8. #28 Re: Pinched a wire or harness, how screwed am I?
    Jun 2017
  1. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  2. wire harness
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 12-29-2012, 05:31 PM
  3. wire harness
    By BLKGP in forum Audio, Security & Visual Electronics
    Last Post: 10-25-2009, 11:38 AM
  4. 04 GP GT Wire Harness.....
    By skubasteve! in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 03:41 PM
