Thread: Firing Up Motor After 7 Months on Jack-Stands
Results 21 to 40 of 70
  1. #21 Re: Firing Up Motor After 7 Months on Jack-Stands
    Mar 2017
    Internet
    Just don't paint it bright yellow and black. It'll look like a bumble bee and you will never hear the end of it.
    Just ask Scott...hahahahahaha
  2. #22 Re: Firing Up Motor After 7 Months on Jack-Stands
    you bee the only one talkin bout it. aint ya now lol
  3. #23 Re: Firing Up Motor After 7 Months on Jack-Stands
    Mar 2017
    Internet
    No one stirred up that nest...I mean thread in a while. Bzzzzzzzzz
  4. #24 Re: Firing Up Motor After 7 Months on Jack-Stands
    well theres gray, more like primer, but yeah, its lame.
    and that killa bee look
    cant even see all the yellow once installed.
    unless your under it of course lol
    2 plus years since painted. nothing holds up like you'd like it too.
  5. #25 Re: Firing Up Motor After 7 Months on Jack-Stands
    Quote Originally Posted by BillBooost37 View Post
    for real tho
  6. #26 Re: Firing Up Motor After 7 Months on Jack-Stands
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Welp... Bad news. She didn't wanna turn over. No video. She stuttered, caught for a half second, and went back sounding like it did when priming it. Eh-eh-eh-eh-EH. God damn it. Tried turning the key a few more times but soon gave up. Same thing every time. No engine work was done so what could it be? My Bluedriver
    code reader picked up 1 code: P0107, MAP Circuit Low.
    First and only thought = fuel pump. Maybe I did the RaceTronix rewire wrong? I couldn't hear the pump priming when turning the key. Before the rewire, with the stock setup, I could definitely hear it booting up. However, I've got pressure at the schrader valve. Comes out like a volcano. So clearly there's pressure. The fuel lines were new and filled with air, so something pushed that out. I should probably rent the fuel pressure gauge from Autozone and see if I can rule that out.
    All in all, pretty ****ty. Time to start troubleshooting.
  7. #27 Re: Firing Up Motor After 7 Months on Jack-Stands
    hangover park IL
    if you did not pull the fuel pump relay when priming you probably flooded it and wet it down the spark plugs
    ~James~ Psychotic Gearhead
  8. #28 Re: Firing Up Motor After 7 Months on Jack-Stands
    Dec 2015
    Chicago, IL
    I did not pull the relay. Didn't know I had to... When I did my LIMs, I primed it just like today without any trouble. Fired right up then. Thought to do the same thing this time.
    Flooding an engine doesn't really harm it from what I understand. Is that correct? Do you think it will be good to go tomorrow, after it dries out all night?
  9. #29 Re: Firing Up Motor After 7 Months on Jack-Stands
    Mar 2017
    Internet
    It's not that easy to flood one of these while priming. Pull a plug, if it's wet then pull them all. Dry them off. Crank it over for a few seconds. Drop plugs back in and you should fire up.
  10. #30 Re: Firing Up Motor After 7 Months on Jack-Stands
    Dec 2015
    Chicago, IL
    Ok. Thanks BillBoost. Gonna try that. I hope thats all it is. I will be out working on it this afternoon. Will report back.
  11. #31 Re: Firing Up Motor After 7 Months on Jack-Stands
    Dec 2015
    Chicago, IL
    Shyt. I couldn't wait. Wasn't dressed for car work. Was out signing up my son for Saturday Polish school. He wasn't too happy about school on Sat.
    She didn't start tho. First thing I did was check the schrader for pressure seeing if anything changed overnight. Again, it was bursting. Checked unions on the fuel lines for leaks, no leaks. Turned the key almost ON, this time I could definitely hear the pump priming.
    The code for the MAP sensor was because I left it unplugged after fixing the vacuum line connection. DOH!! Plugged in now, but didn't help in getting it started
    Anyway, pulled plug 5 and 3. Both dry. Plugs are copper, Mastercraft, with 1000 miles on them. Known to be good.
    To prime the engine yesterday, I pulled the wires off the ICM. I could see the coils sparking. Coils are pretty new, known good. The way it just cranks and cranks makes me think of an igntion issue. In the "My Ride" thread about this car, I posted (back in April I think) pictures of cracks in the insulation on the wires from the ICM harness. Despite the cracks, and green copper showing, I left it on. It was Known Good despite the cracks. Since then, I purchased a gently used ICM harness from a member on here, HighOctaneRacing. Looks to be in great condition. Maybe that's the problem, bad wires leading to ICM?
    Is it worth checking the pressure at the schrader valve despite it bursting? Or can we call fuel pressure as being good? Thanks guys.
  12. #32 Re: Firing Up Motor After 7 Months on Jack-Stands
    Dec 2015
    Chicago, IL
    Driving back over to work on the car now. Gonna replace the ICM harness. Rule that out.
  13. #33 Re: Firing Up Motor After 7 Months on Jack-Stands
    Dec 2015
    Chicago, IL
    So I'm sitting here now, pondering and staring at the car. The more I think about it, the more convinced I am that the problem is fuel related. Stangely, I'm not getting any fuel at the schrader valve anymore. Despite trying to crank it again. I can't consistently hear the pump priming. Thought I heard it earlier but can't really repeat it. Was probably just convincing myself I did. Like I said, the stock setup was unmistakable. Sounded kinda cool, like a system booting up. No sound like that now though. ****ty... ****ty.
    I'm not touching the ICM for now. Luckily I kept the Racetronix instructions. Going to check my work, and if it's correct and still not starting then I will undo the rewire, go back to stock setup, and see if it starts. If still nothing, then I will remove the fuel pump and bench test it.
    That's the plan. If all that proves fruitless, ICM harness will be next.
    I mounted the hookup for the rewire under the rear subframe which means I need to drop it again. Terrible. Dropped it like 10 times now. Not looking forward to it.
  14. #34 Re: Firing Up Motor After 7 Months on Jack-Stands
    check the fuel pump fuse.
  15. #35 Re: Firing Up Motor After 7 Months on Jack-Stands
    Quincy, Mass
    Does it squirt out of the valve or just pour out?
    No more GP 04 Impala SS Indy:
  16. #36 Re: Firing Up Motor After 7 Months on Jack-Stands
    Dec 2015
    Chicago, IL
    Scotty. The rewire kit came with its own fuse connection. 20amp. Checked it, it was fine. The stock fuses are obsolete at this point right, because of the rewire? I didn't check stock fuses. That kit comes with its own relay as well. But I was thinking, do I need to pull that stock stuff out? Like the fuse, resistor, etc.? Does that pin need to be bent or something? Here's a link to the kit:
    http://www.racetronix.biz/itemdesc.asp?ic=FPWH-025&Tp=
    Swiggles. At my first post, after priming it, and trying to start it for the first time, and failing, then checking the schrader, it squirted out good. This morning it was still squirting but maybe less so. Tried starting it, nothing. Just cranks, but doesn't catch. Checked schrader again maybe 2 minutes after that and there was noticeably less pressure. Maybe something is obstructing flow? Crap from the tank? Brand new fuel filter clogged already? Bad fuel? I poured 3 gallons of fresh 93 octane into what was in the tank already. There wasn't much in there. But lets say that gas was a year old. Last used to run the car in March/April of this year.
    I'm pretty confident I did the Rewire correctly. We'll see....Got the rear subframe almost dropped. Will be back on Tuesday to work on it some more.
  17. #37 Re: Firing Up Motor After 7 Months on Jack-Stands
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  18. #38 Re: Firing Up Motor After 7 Months on Jack-Stands
    Mar 2017
    Internet
    Ok.. let's back up and start with the basics. Before... you had plenty of fuel a schrader, your plugs are dry and you know your coils throw spark.
    Make sure all your connections have been reconnected. Grab your can of brake clean, carb clean, tb cleaner.. all these are flameable. If this is a SC motor, spray some from the can into the vacuum fitting below the SC snout on the LIM. put that line back on and go fire it up. When I say spray some.. give it one mississippi. That's all you should need to check for fuel. If it fires and dies, the issue is fuel (I'm fairly sure it is).
    Now that you know it's fuel.. let's trace it down. Turn key on and off twice. This should give schrader plenty of pressure again. If you have pressure there, then we can move on.
    Since there would be fuel in the rail, next up is injectors. Mainly is the pcm telling them to fire. The only time injectors should not prime the cylinders that I am aware of is if the throttle is held at 100%. Because putting the pedal to the floor is how you clear a flood situation in an FI engine. So let's not do that.
    This shouldn't be too bad. If you have fuel pressure at rail, it's not the pump.
  19. #39 Re: Firing Up Motor After 7 Months on Jack-Stands
    Dec 2015
    Chicago, IL
    Yep. Had pressure at schrader, and pressure seemed to decline each time checking it thereafter.
    I have some carb cleaner to try that starting trick. It is a SC 3800. That vacuum connection comes to a T. Do I yank the entire T off, and spray in there?
    Found this link:
    http://www.grandprixforums.net/threa...pressure/page2
  20. #40 Re: Firing Up Motor After 7 Months on Jack-Stands
    spray right in the tb, avoid hitting the maf if you can, aka stick the tube in past it, then crank the engine.
  1. Jack stands?
    By GXP44 in forum 5.3L V8 (LS4)
    Last Post: 08-06-2017, 09:06 AM
  2. 99 GTP Motor Swap over next 3 weeks - where to put jack stands?
    By Elite6 in forum General Tech Discussion
    Last Post: 08-02-2012, 06:39 PM
  3. where to place jack stands?
    By twoleos617 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-18-2009, 11:50 AM
