Thread: Need help with vibrating issue as I go faster.
Results 1 to 8 of 8
  1. #1 Need help with vibrating issue as I go faster.
    Feb 2014
    Grand Forks, North Dakota
    It feels like it is mainly coming from the driver front area. A couple years ago I had both axles replaced and that took care of vibration on acceleration from 30-40 mph because the boot on the axles were dry rotted and slinged grease everywhere. A few weeks ago I replaced both the inner and outer tie rod on the driver side because there was play in the tire when grabbed at the 9 and 3 position. Replacing the tie rod didn't fix the vibration. So I had a buddy look behind the tire while i rocked the tire. He immediately noticed the ball joint was moving a lot. So I hopped on rock auto and bought a new control arm with a ball joint already included. I replaced that about a week ago, after replacing I went for a test drive out on the interstate and it still vibrated.
    I don't think it's a hub issue because I grabbed the tire at 12 and 6 and there wasn't any movement. It is also not a balance issue because the tires have been rotated multiple times and it still come from that area. Surprisingly there is no uneven wear on the tires. Although now the alignment is slightly off after replacing the tie rod.
    When at highway speed and I go into a quick little dip in the road, so when the suspension compresses, the vibration increases then lets off after getting out of the dip. When load is held on the drivetrain for example when cruise is set the car vibrates but once I switch the cruise off the vibration lets off but you can still feel it slightly.
    When there is a right turn on the interstate and all the weight of the vehicle shifts to the left it makes the car vibrate just a little more. When the road turns left and the weight shifts to the right side of the car then the vibration is less.
    What could it be??
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  2. #2 Re: Need help with vibrating issue as I go faster.
    GT Level Member Gregorius's Avatar
    Davenport, IA
    So loading the Left hand front suspension causes the vibration to increase. With everything else being replaced, LCA's and tie rods, the only thing really left is the Strut mounts. But that seems to be counter-intuitive.
    How's that Cradle to Tranny mount look on the left side? Pry up on it, see if it's separated?
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  3. #3 Re: Need help with vibrating issue as I go faster.
    Feb 2014
    Quote Originally Posted by Gregorius View Post
    thats what my next thought was to check the tranny mount since it's on that side.
  4. #4 Re: Need help with vibrating issue as I go faster.
    May 2017
    Dirtyzville, Mizzery
    I read the title and just wanted to reply to: Vibration as I go faster...
    ...so slow down?
    lol
    For upgrades/no future issues be sure to do solid rubber lower trans/engine mounts (usually the motor mount is the one that lets go, not the trans) and flip the upper dog bones 90* so you take stress off of them, too.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  5. #5 Re: Need help with vibrating issue as I go faster.
    Feb 2014
    Quote Originally Posted by blueguy91 View Post
    A few years back I did flip the dog bone mounts 90 degrees
  6. #6 Re: Need help with vibrating issue as I go faster.
    Feb 2014
    So this past Saturday I checked the tranny mount and it looked good. Now i have no more ideas, unless its internal to the transmission which in that case i don't want to touch it.
    Anybody else know what it could be?
  7. #7 Re: Need help with vibrating issue as I go faster.
    Sep 2015
    Cheyenne, WY
    Have the tires checked.
    A cord may have shifted that could cause the vibration.
    2007 Antique Bronze Metalic Grand Prix GT...bone stock.
  8. #8 Re: Need help with vibrating issue as I go faster.
    Feb 2014
    Quote Originally Posted by LEVELX View Post
    The tires have been rotated numerous times and it still comes from the same area. It also did it on the last set of tires that were on the car.
  1. Car is vibrating
    By Blue GTP in forum General Tech Discussion
    Last Post: 08-25-2014, 01:23 PM
  2. Pontiac 2003, faster and faster please help
    By Osvaldo831 in forum Visual/Body Modifications
    Last Post: 11-07-2013, 09:11 PM
  3. '06 GP Issue with Vibrating+Clicking Sound
    By sigmaspartan in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2013, 03:34 PM
  4. a/c fan vibrating?
    By WOTFTW in forum General Tech Discussion
    Last Post: 06-18-2012, 09:42 PM
  5. Vibrating issues
    By Piggy in forum General Tech Discussion
    Last Post: 01-31-2010, 12:44 AM
