Thread: Random stall when coming to a stop
Results 1 to 4 of 4
  1. #1 Random stall when coming to a stop
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    When coming to a stop the engine dies. It seems to happen at random with no other noticeable symptoms. A few months ago I had a P0140 code so I replaced the oxygen sensor and drove it 500+ miles with no issues. I figured that was the cause, but I was driving today and it stalled twice within two blocks.
    I just scanned for codes and it came up clear. After it stalls, it fires right back up on first crank. I'm thinking fuel pump resistor but wanted to see if anyone else has ideas on what I should check for.
    '97 GTP with 130K miles.
  2. #2 Re: Random stall when coming to a stop
    check your fuel pressure at the rail.
    could be a bad maf too.
  3. #3 Re: Random stall when coming to a stop
    GT Level Member mguzzo's Avatar
    Buffalo NY
    does it stall, then the tach go to zero? MAF or fuel pump. Not resistor, that would be a stall at startup getting into heavy throttle, not just rolling to a stop. make sure the O2 harness isn't rubbing against something
    or does the tach go to zero, then it stalls? crank position sensor
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  4. #4 Re: Random stall when coming to a stop
    Apr 2009
    Upper Darby, PA
    It happens so irregularly that I'm usually too caught off guard to notice the tach.
    O2 wires are free and clear. The fuel pump was replaced a few years back so hopefully it's not that.
    I will check out both of your suggestions and report back.
  1. rpm drops when coming to a stop
    By bocou92 in forum Engine
    Last Post: 08-28-2014, 08:58 AM
  2. Doing CPS/random stall research...
    By GoldGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2013, 07:50 PM
  3. 2000 gtp random stall issue
    By Deltabull in forum General Tech Discussion
    Last Post: 04-26-2012, 04:19 PM
  4. Trouble downshifting when coming to a stop.
    By wytmyk420 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-31-2011, 05:04 AM
  5. Clunk when coming to stop and/or accelerating
    By trailshredder in forum Brakes/Suspension/Chassis
    Last Post: 04-01-2010, 05:43 PM
