I have a 2000 Buick regal supercharged 184,000 miles. Last winter in November it would not start, I sprayed intake cleaner into throttle and it started right away. It did this on two diff occasions. I continued to drive it regularly for a few weeks.
It then started to do this again and this time it would not start even when spraying intake cleaner into throttle. I checked fuel pump pressure, changed relay etc and all checked out fine.
It sat on the street for a few weeks and randomly started when i tried and i put it in my backyard ( it was probably a warmer day). Well it set over the rest of the winter until about March and it has started normally ever since, i go out a start it a couple times a week.
I want to start driving it again but don't want to go through this once it gets cold again. I read a few things online and I was going to change the crank sensor, but like I said it has been starting every-time.... If it was the crank would it start now? Could it have been bad gas?
