Thread: Wheel bearing replacement?
Results 1 to 13 of 13
  1. #1 Wheel bearing replacement?
    Jun 2017
    Idaho
    Just replaced my brakes with a great z23 brake kit from power stop, and yes i'm sure i paid too much for brakes on 'just a grand prix' but brakes are something I want full confidence in.....
    Heres the thing, now with fancy new brakes that have nice tight tolerances and not much wear... they scrape pretty bad turning left and some going straight... mostly passenger side but some driver side too.... Pretty damn sure it's the wheel bearings. Looking for recomendations now, I DON'T want to be replacing them again a year from now but really don't want to dump a ton of more money into this car. The full hub assemblies look to be all that's available?
    will the duralast do?
    http://www.autozone.com/suspension-s...6_820340_22589
    Or does one have to spring for the MOOG's....
    http://www.autozone.com/suspension-s...831195_0_22589
  2. #2 Re: Wheel bearing replacement?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Get the Moogs, do the job once and be done with it.
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  3. #3 Re: Wheel bearing replacement?
    SKF's work good too.
  4. #4 Re: Wheel bearing replacement?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Get the Moog or Timken from rockauto.com . There is always a 5% discount code available online. The powerstops work great I have the 2010 Impala front 12" dual piston set up from them and way better braking performance. Also check the brake hardware and backing plate for the scraping noise. Usually the bearing will cause more of a growl while driving straight and sometimes the noise will lessen some on the turns.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  5. #5 Re: Wheel bearing replacement?
    May 2017
    Dirtyzville, Mizzery
    Never evererererererrrrr had ANY issues with Timkin bearings for all the WBody's I've had.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  6. #6 Re: Wheel bearing replacement?
    SWPA
    Agreed on Moogs. I changed both front and one rear with them. The one rear one did fail, but it was replaced under warranty without hassle.
    That's another thing, while Rockauto may save you a few dollars you have to deal with the hassle of shipping back items for warranty issues. The Moog is about $90 there and about $10 for shipping. You can get the Moog for about $110 with Advance by using the 30% code and do the buy online, pickup in store.
    This way if you do have a failure you can get it taken care of locally.
  7. #7 Re: Wheel bearing replacement?
    Jun 2017
    Idaho
    I see decent prices on timkin, or these from summit
    https://m.summitracing.com/parts/mog-513121
    Opinions? Concerned since this is almost half the price of the moogs from AutoZone. If the moogs are nicer I'll grab em, but if they're some... lesser moogs or something...
  8. #8 Re: Wheel bearing replacement?
    Jun 2017
    Idaho
  9. #9 Re: Wheel bearing replacement?
    The part number on summit is the same as the one from autozone, it's the same bearing and a different price.
    If summit is cheaper, buy from summit.
  10. #10 Re: Wheel bearing replacement?
    GTP Level Member buickman104's Avatar
    NYC
    I would also recommend torquing the wheel bearing to spec. I has a string of wheel bearings go bad after 1 or 2 years, until I started torquing them to spec and I haven't had to change a wheel bearing in 3 years so far... knock on wood.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  11. #11 Re: Wheel bearing replacement?
    Jun 2017
    Idaho
    Apologies for wack double post,
    Thanks guys
  12. #12 Re: Wheel bearing replacement?
    SWPA
    If your car has ABS that is not the right one.
  13. #13 Re: Wheel bearing replacement?
    Quincy, Mass
    I personally prefer timken, never had an issue with them.
    No more GP 04 Impala SS Indy:
  1. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  2. Wheel rocking still... already changed wheel bearing. Ideas?
    By jmn in forum Introductions/Noob Questions
    Last Post: 09-30-2013, 09:27 AM
  3. Another wheel bearing?
    By smoke14 in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2013, 06:07 PM
  4. wheel bearing replacement?
    By loganrick in forum Brakes/Suspension/Chassis
    Last Post: 01-10-2012, 12:28 AM
  5. Wheel Bearing Replacement. Question!
    By brownb66 in forum General Tech Discussion
    Last Post: 11-11-2009, 12:04 PM
