Thread: why my car overheats
Results 1 to 17 of 17
  1. #1 why my car overheats
    Feb 2017
    Puyallup
    When I set at a red light for awhile or in traffic my car over heats has plenty of coolant in the radiator and in the overflow tank, replaced water pump, upper radiator hose, thermostat
  2. #2 Re: why my car overheats
    GTP Level Member buickman104's Avatar
    NYC
    Are your fans turning on?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  3. #3 Re: why my car overheats
    Feb 2017
    Puyallup
    Quote Originally Posted by buickman104 View Post
    my fans are working
  4. #4 Re: why my car overheats
    Jun 2017
    Idaho
    Bought mine with dexcool + green coolant.... sludge caused this and messed up the tstat.
  5. #5 Re: why my car overheats
    Quincy, Mass
    Quote Originally Posted by BigNelson76 View Post
    Straight dexcool will sludge too. You need to flush out the system. Radiator could be clogged in some areas too, use a laser temp reader to check that. Coolant passages in the engine could be clogged too with sludge.
    No more GP 04 Impala SS Indy:
  6. #6 Re: why my car overheats
    SWPA
    Have you properly bled the system of air?
  7. #7 Re: why my car overheats
    My guess is air is trapped or the coolant temp sensor it wrong.
    The sensor puts out a reading to the dash and the computer. You can use a scan tool to see if the computers temp is in line with what the gauge reads. The gauge cluster isn't super accurate but if the cluster shows half way or a little less and the computer shows 190-195 you are fine but if the cluster is showing 3/4 or more on the gauge and the computer is at 190-195 then the ECT is likely at fault.
  8. #8 Re: why my car overheats
    New dexcool won't, but old dexcool will sludge with air in the system so possible it could be bad flow if was never done before this happening.
  9. #9 Re: why my car overheats
    Jun 2017
    Idaho
    Old dexcool sure, but it's not nearly as disgusting as a old dexcool new green mix.
    I was pretty ticked.
    I've had Zero issues with new dexcool.
  10. #10 Re: why my car overheats
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I recently witnessed what dex cool does to an engine. When I pulled the heads off of my 07 just about all the passages were plugged with hardened dex cool crap. There was no flush in the world going to get that stuff out.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  11. #11 Re: why my car overheats
    Aug 2016
    CT/RI Border
    Temp Sensor/sending unit would be my go to change.
    Did you have a catastrophic failure at one point which lead to all the work you've done or are you throwing parts at the problem?
    Sent from my ASUS_Z00TD using Tapatalk
  12. #12 Re: why my car overheats
    Feb 2017
    Puyallup
    I bought the car from some druggy's and have been fixing a mess of stuff on the car
  13. #13 Re: why my car overheats
    Aug 2016
    CT/RI Border
    Right, but you're describing a temperature issue, did it have a catastrophic overheat or are you replacing all of these cooling parts trying to track down the issue?
  14. #14 Re: why my car overheats
    Feb 2017
    Puyallup
    well the water pump was shot and the upper hose blew out on a road trip so if that what you are talking about when you say catastrophic over heat then i would say yes
  15. #15 Re: why my car overheats
    Aug 2016
    CT/RI Border
    Typically catastrophic overheat is when the gauge spikes due to major component failure, like the radiator getting a large hole the water pump or serpentine failing and it going unnoticed. Losing a hose can sometimes fall into this category if it goes unnoticed for long enough to cause damage.
    That said, replace sending into/sensor. Should be screwed into the cover plate for the thermostat iirc.
    Also, I didn't see it answered apologies if you did, is it actively overheating or is the gauge just overheating?
  16. #16 Re: why my car overheats
    Feb 2017
    Puyallup
    well it seams to be the gauge over heating but not to sure this car is a mess but i think it can be saved poor car just needs some loving
  17. #17 Re: why my car overheats
    Banned
    I had the same problem after replacing the same parts you mentioned. I fixed it by putting in a fresh radiator. I think I could have solved it by removing the old radiator and power washing it. There was large areas that were filled in with gunk preventing the air to flow through the radiator.
  1. Car overheats at an idle
    By mok4200 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2014, 03:24 PM
  2. almost overheats after coolant flush
    By disallow in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2012, 10:35 AM
  3. 97 GTP Overheats
    By sjdeades in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-14-2011, 05:17 PM
  4. Overheats after LIM change- HELP!
    By tankerchief in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2011, 12:52 AM
  5. HELP! Overheats at idle
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 11-03-2009, 04:30 PM
