Thread: P1125 and P2138, replaced pedal won't go away
Results 1 to 3 of 3
  1. #1 P1125 and P2138, replaced pedal won't go away
    SE Level Member Metal Links's Avatar
    Dec 2013
    NJ
    About 2 weeks ago I got p2138(current) and p1125(pending), 04 GP.I replaced the gas pedal and it was fine for a few days then I changed out my battery and it started to come back. Today, while it was raining, it came on 7 times in a 6 mile drive. It seems to trigger when Im cruising between 1000-1400, it'll jump a couple hundred RPMs then fall back or if I stab the throttle.
    In last two weeks I have cleaned MAF, throttle body and the throttle wire connector. Clean 3 grounds in the cabin and cleaned the green and blue(?) wire connectors under the driver side dash. About a month ago I also rewired the front driver ABS wire(was water in it) and when I cut into the lower wire loom I accidentally cut a brown and green wire, fixed with solder butt splices. Also installed a strut tower bar.
  2. #2 Re: P1125 and P2138, replaced pedal won't go away
    Dec 2013
    NJ
    Update​;
    Cleaned the connectors going to the body control unit and took off the TB and cleaned it. There was something like a pin sliding back and forth in the TB. Is that normal? Went for a drive and the CEL came on twice and idle was high, about 800 compared to mid 600s.
    I saw a TSB for the IP to Body connector being corroded, where is that exactly located?
    EDIT; It threw the 2nd CEL when I had cruise control on. Would it be a bad TB or 5v reference signal?
  3. #3 Re: P1125 and P2138, replaced pedal won't go away
    Mar 2015
    Malta, MT
    Metal Links
    I have had the same issues but with additional codes of P2120 and P2125. I have replaced both pedal and TB with no help. I have searched the interweb for wiring diagrams and such with no luck. I have checked voltage at the pedal and have voltage at both pins that should have voltage but when the pedal is attached they read some difference. i have tried to find ground locations and also thought of a body control unit but can't find any info. So did you solve your issues?
    Thanks Rick
  1. 2004 gt accelerator position problem with codes p1125, p2120, p2138
    By 2004 GT GIRL in forum General Grand Prix Discussion
    Last Post: 09-30-2016, 03:15 PM
  2. Replies: 0
    Last Post: 05-17-2015, 10:47 PM
  3. 2008Grand prix fault codes p1125-p2120-p2138
    By daviddawg in forum Introductions/Noob Questions
    Last Post: 04-04-2014, 02:10 PM
  4. NEED HELP: Codes popped P1125, P2120, P2125, P2138, P0401, P0068 and P0101
    By deejayfb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2013, 04:17 AM
  5. P2138 P1125 codes
    By jlusleton in forum General Tech Discussion
    Last Post: 09-23-2011, 05:35 PM
