Thread: P1125 and P2138, replaced pedal won't go away
Results 1 to 3 of 3
Threaded View
  1. #2 Re: P1125 and P2138, replaced pedal won't go away
    SE Level Member Metal Links's Avatar
    Dec 2013
    NJ
    Update​;
    Cleaned the connectors going to the body control unit and took off the TB and cleaned it. There was something like a pin sliding back and forth in the TB. Is that normal? Went for a drive and the CEL came on twice and idle was high, about 800 compared to mid 600s.
    I saw a TSB for the IP to Body connector being corroded, where is that exactly located?
    EDIT; It threw the 2nd CEL when I had cruise control on. Would it be a bad TB or 5v reference signal?
  1. 2004 gt accelerator position problem with codes p1125, p2120, p2138
    By 2004 GT GIRL in forum General Grand Prix Discussion
    Last Post: 09-30-2016, 03:15 PM
  2. Replies: 0
    Last Post: 05-17-2015, 10:47 PM
  3. 2008Grand prix fault codes p1125-p2120-p2138
    By daviddawg in forum Introductions/Noob Questions
    Last Post: 04-04-2014, 02:10 PM
  4. NEED HELP: Codes popped P1125, P2120, P2125, P2138, P0401, P0068 and P0101
    By deejayfb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2013, 04:17 AM
  5. P2138 P1125 codes
    By jlusleton in forum General Tech Discussion
    Last Post: 09-23-2011, 05:35 PM
