Whohoo (or however you spell that). I found the leak. It's the water pump. Had to pull of the harmonic balancer in plans to pull the timing cover gasket but now I no longer need to.
And it's free!!
Quick questions. Is there supposed to be oil in the crank shaft? Can I spill coolant on the crank(when I take the pump off)? Can I re use the coolant? it is not old
