Thread: Radio not recieving power
Results 1 to 19 of 19
  1. #1 Radio not recieving power
    Nov 2011
    Indiana, PA
    I have a 2008 GP Base model,put a Pioneer AVIC-X2 in a few years ago, worked great until last night... was driving and noticed it had not turned on with the car... pulled over shut the car down, opened the door to turn the RAP off... started it back up and it came on... ok good, well this morning its off again, tried the same thing... nothing dead
    today, checked the 25 amp "Radio" fuse, looked fine, checked it with a continuity meter, checked out...
    next thing RAP relay, it was clicking when the car turned on, not always a sign its good though, changed it with another relay same result, just to be sure changed it with the crank relay (since they are the same part) car started fine.... RAP relay is fine....
    checked the voltage at the wiring harnes, 0v DC
    so its not the head unit, its not the radio fuse, not the RAP relay.... not the head unit.... that else could it possibly be? anything I can check, or wires to follow that should have voltage i can put a meter on? thanks!
  2. #2 Re: Radio not recieving power
    Omaha, NE
    If you still have your stock head unit, see if it gets power.
  3. #3 Re: Radio not recieving power
    Nov 2011
    Indiana, PA
    tried it and nothing...
  4. #4 Re: Radio not recieving power
    Houston
    You said you continuity tested the fuse, but did you test for voltage at the fuse?
  5. #5 Re: Radio not recieving power
    Nov 2011
    Indiana, PA
    not exactly 100% sure how to do that, I tried to put the pos lead from the multimeter on one of the top legs of the fuse (the metal parts that are accessable from the top of the fuse) and tried to find a ground to test against but not sure if I got one or not tried against unpainted body metal and got 0v
  6. #6 Re: Radio not recieving power
    Nov 2011
    Indiana, PA
    sorry, I am an idiot, I had the multimeter pos lead on the wrong fused side of the meter... after catching that... radio fuse to ground is +14.5v so it has power at that point at least, where does the wire go from there? straight to the harness?
  7. #7 Re: Radio not recieving power
    Houston
    Wow, 14.5v is pretty high..was the car running?
  8. #8 Re: Radio not recieving power
    Nov 2011
    Indiana, PA
    yes, my DIC also says the car voltage is 14.38v
  9. #9 Re: Radio not recieving power
    Nov 2011
    Indiana, PA
    some more info..... just had the check engine light come on, but a reader on it and gave me an "intermittent sensor connection" forget the code, have to go back and check agian... but when I put the factory radio in it's buttons light up, but the radio doesnt power up (+12v vs RAP power i guess)
    Edit: scan code is P0454 Evaporative Emission Control System Pressure Sensor Intermittent
  10. #10 Re: Radio not recieving power
    Houston
    If it was running then the 14.5v is normal. If you plugged in your factory deck and it lit up, your constant 12v is there, it's the switched 12v thats missing. Check your voltage at the yellow and red wire on the aftermarket harness.
  11. #11 Re: Radio not recieving power
    Nov 2011
    Indiana, PA
    0v... getting 0v from the same pins on the car's radio harness... onlu the ilummination pins have voltage
  12. #12 Re: Radio not recieving power
    Nov 2011
    Indiana, PA
    starting to think there is a short in the car's wiring harness... today its working perfectly fine! turned on the car and the system powered right up... spent all day yesterday trouble shooting this... today works fine
  13. #13 Re: Radio not recieving power
    Houston
    Yeah man thats really strange. If it were a short, you'd end up with some blown fuses. There must be a module between the factory harness and the fuse panel that is on it's way out.
  14. #14 Re: Radio not recieving power
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Are you getting 0 volts to the power on wire or the power wire?
  15. #15 Re: Radio not recieving power
    Nov 2011
    Indiana, PA
    Quote Originally Posted by csssaint12 View Post
    not sure what you mean, when I checked it I was checking from the factory harness orange wire (the RAP power) to ground and it had zero volts...
    checked the radio location in the interior fuse box to ground and had +12v
    checked RAP at the interior fuse box and had +12v
    so what ever happened happened between the fuse box and the factory wiring harness plug
  16. #16 Re: Radio not recieving power
    tap a new wire from the fuse box to the radio, see if it powers up?
  17. #17 Re: Radio not recieving power
    Nov 2011
    Indiana, PA
    yeah if you run a jumper wirse from the fuse box to it, works fine...
    where does that wire run? does it run directly from the fuse box to the radio or does it go somewhere else first? don't want a short in the system if there is one, but if there is one makes me wonder what else is wrong since this worked fine for 3yrs now this
  18. #18 Re: Radio not recieving power
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    Aye Captain Kirk, I am giving it all the power I can, Mr. Sulu, damit it man, we need more power!
  19. #19 Re: Radio not recieving power
    Jul 2017
    CT
    Quote Originally Posted by bluebsh View Post
    Do you remember any details of what you finally did for this problem? I have the exact problem going...
  1. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  2. HELP!! how do you power up power seat?
    By nemesis in forum General Tech Discussion
    Last Post: 04-14-2010, 11:56 PM
  3. Radio and HUD
    By the955iman in forum Audio, Security & Visual Electronics
    Last Post: 02-08-2009, 03:17 PM
  4. help with radio
    By Matto211 in forum Audio, Security & Visual Electronics
    Last Post: 02-08-2009, 01:32 AM
  5. Hey! Here is my story of recieving my GTP! Read!
    By Freebeer187 in forum Introductions/Noob Questions
    Last Post: 08-01-2008, 06:57 PM
