Thread: Lost a belt - GP may be dead
Results 1 to 20 of 108
  1. #1 Re: Lost a belt - GP may be dead
    Akron, Ohio
    Watched 2 videos. One guy removed the hub and not the strut. The other guy removed the strut but not the hub. I had the rotor off so I figured I'd remove both. I know I always give more information than you need, but when I replaced the hub last time the bolts for the hub would not torque but felt like hey were stretching so I ordered new bolts but never put them on. Part of this process is putting in parts that I have had laying around and never got to putting on. Like the PCV valve, etc
    Serious question. I still have the electrical gremlin. Gauges and lights and faults when below freezing. When I took out the battery, the positive connector was as tight as would go but still loose. Could this cause the car to run but the electrics to be messed up.
  2. #2 Re: Lost a belt - GP may be dead
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Quote Originally Posted by dgjks6 View Post
    , the positive connector was as tight as would go but still loose. .
    The terminal bolt might be bottoming out into the battery. Take it off and shorten it w/ a grinder.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  1. Alternator belt...$5 Damaged caused by belt...Priceless
    By sugaryuk in forum Off Topic Discussion
    Last Post: 06-30-2015, 11:41 PM
  2. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  3. Is it dead?
    By klj5022 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2011, 10:49 AM
  4. Hello I am the Dead-Man
    By iamthedeadman in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:31 PM
  5. car = dead
    Last Post: 02-10-2009, 09:03 PM
