Thread: 2006 Grand Prix Fuel Pump Replacment
Results 1 to 3 of 3
  1. #1 2006 Grand Prix Fuel Pump Replacment
    Jul 2017
    Indiana
    Motor is throwing code that it's running lean. I havnt checked pressure but GM said it's most likely fuel pump. How hard is it to change? It doesn't have the access door like the previous models/years had which sucks. Any tips would be helpful as look forward to my endeavor! Could it be MAF, EGR. It starts hard takes about 5 seconds before it will start. Today when I started it and went to give it gas it started pulsing in Rpms-gaining and losing power for about -5 seconds then took off.
  2. #2 Re: 2006 Grand Prix Fuel Pump Replacment
    Jul 2017
    Massachusetts
    so many things could make it run lean. That said, the pump isn't that difficult to change. There is an access hatch in the trunk floor. At least, there is one in the '04, I would expect one in the '06? I would get a pressure gauge first though, and check the fuel pressure on the rail. A gauge is a lot cheaper than a pump, and will save you the cost of needlessly replacing the pump.
    Most likely cause of running lean is a vacuum leak somewhere after the MAF.
  3. #3 Re: 2006 Grand Prix Fuel Pump Replacment
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Quote Originally Posted by deekstercaddy View Post
    No access from the trunk on this year
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  1. 2006 Grand Prix fuel pump replacement
    By Dsize49 in forum General Grand Prix Discussion
    Last Post: 07-19-2017, 08:28 PM
  2. 97 Grand Prix Fuel Pump
    By clcruce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2015, 03:05 PM
  3. Fuel pump for 2000 Grand Prix GT
    By keonmakesbeatz in forum Wanted To Buy - Parts
    Last Post: 09-01-2014, 12:28 PM
  4. 2007 grand prix fuel pump
    By minnieme40 in forum General Grand Prix Discussion
    Last Post: 05-23-2013, 05:47 PM
  5. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
