Thread: OEM Wiring???
Results 1 to 3 of 3
  1. #1 OEM Wiring???
    Jun 2017
    Pennsylvania
    Hey! Does anyone know if our cars are prewired form the factory for all available options? For example, lets say you can did not come with leather heated seats.. You get a set and u install them. Will the wiring for the heated seats already be in the dash and under the carpet? I know some manufacturers have the wiring already run for stuff like that...
  2. #2 Re: OEM Wiring???
    I would say most aren't wired.
    The question is asked about the heads up display wiring from time to time, it's just the luck of the draw if the pigtails are behind the cluster.
    You'll have to pull up the carpet and see if any open plugs are there.
  3. #3 Re: OEM Wiring???
    Quincy, Mass
    Some have the plugs for a digital dic and heads up display but I don't there is for heated seats. However the heated seats might plug right in and work, i believe the harness connections are the same.
    No more GP 04 Impala SS Indy:
  1. led wiring help
    By dpzelenak in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2011, 04:13 PM
  2. Amp and sub wiring
    By beerfun in forum Audio, Security & Visual Electronics
    Last Post: 08-24-2010, 01:33 AM
  3. Amp Wiring
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 08-26-2009, 10:08 PM
  4. Need help wiring amp
    By jjwitty in forum Introductions/Noob Questions
    Last Post: 07-24-2009, 01:59 PM
  5. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
