Thread: Rollmaster crank sprocket
Results 1 to 9 of 9
  1. #1 Rollmaster crank sprocket
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Does anyone have any tips on getting the Rollmaster crank gear to slide on smooth. As it is now I would have to pound it on with a hammer.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: Rollmaster crank sprocket
    May 2008
    Schuyler, NE
    You may need to take Emory cloth and clean out the keyway. You may also have some rust on the crank keeping it from going on.
  3. #3 Re: Rollmaster crank sprocket
    GTP Level Member
    Jun 2016
    Cleveland ohio
    It's tight before it even gets to the key way.
  4. #4 Re: Rollmaster crank sprocket
    hangover park IL
    When they broach the keyways it deforms the bore at the corners
    ~James~ Psychotic Gearhead
  5. #5 Re: Rollmaster crank sprocket
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Ok then like GTPP said just use some Emory cloth on the rollmaster gear at the key way?
  6. #6 Re: Rollmaster crank sprocket
    Nov 2011
    NY
    They are "TIGHT", and light taps with a hammer isn't unusal. Just make sure you're al aligned properly, lol, or you'll have to get it off and do it again!
  7. #7 Re: Rollmaster crank sprocket
    May 2016
    Burns City, Indiana
    Proper deburring and cleaning and a good polish of the crank too. Then if it needs tapped on a quick way to warm them up is if you have a halogen work lamp or a on top of the stove, little oil and make sure your going on right way. also if you look around for some spray duster tip bottle upside down. You can spray liquid inside bolt hole to cool it down, That and the warm sprocket should slide on with little effort.
    Good Luck
  8. #8 Re: Rollmaster crank sprocket
    SWPA
    As Monza said warming up the sprocket will help it slide on. We use a bearing warmer at work. It heats the bearing up allowing it to fall onto the shoulder on the motor's rotor. 9 chances out of 10, as long as we let it get to its proper temp we don't have to use a hammer and bearing driver.
  9. #9 Re: Rollmaster crank sprocket
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Thanks guys!! I will give it a try when I get home today
  1. Need Crank timing sprocket!
    By suitercrew in forum Wanted To Buy - Parts
    Last Post: 04-28-2017, 09:50 PM
  2. No crank, just click. Replaced starter, still no crank.. help!!
    By Steve98GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2013, 08:48 PM
  3. Camshaft Sprocket Bolt
    By Andre in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2010, 02:23 PM
  4. Camshaft Sprocket Bolt Size?
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 11:18 AM
  5. Drive Sprocket Support Bearing
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2008, 05:50 PM
