Thread: Does anyone know the correct o ring size for the ac condenser lower line?
Results 1 to 2 of 2
  1. #1 Does anyone know the correct o ring size for the ac condenser lower line?
    Sep 2015
    Lansing, Michigan
    I put in a new condenser and tightened the fittings down tight. I replaced the o rings with ones from auto zone in a pack.
    The new o rings appear to be thinner by a mm or 2. Today I was recharging and the lower line blew refrigerant all over after it reached a certain pressure.
    I also had a hard time getting that line to line up properly with the condenser because the condenser was a bit different so I bent the condenser line a bit to make it line up to the line.
  2. #2 Re: Does anyone know the correct o ring size for the ac condenser lower line?
    May 2016
    Burns City, Indiana
    Generally in my everyday job as a tech, if the oring goes on the line, replace with same size. I dont trust the oring packs with parts unless I match them up. NAPA has a great visual book that allows you to lay old orings on it and match them up. Larger oring assortments sometimes have enough of proper size. A GM dealer may be able to sell you the appropriate oring by position.
  1. Lower Control Arm, Is This The Correct PN?
    By born2pdl in forum Brakes/Suspension/Chassis
    Last Post: 05-08-2017, 08:28 PM
  2. Is my fuel line routing correct? Just top-swapped.
    By Runicdionysus in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2015, 02:18 AM
  3. what o-ring size and material for the top trans line fitting?
    By alacran in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2013, 11:42 PM
  4. Correct valve stem size?
    By 02NavyBlue in forum General Grand Prix Discussion
    Last Post: 03-25-2013, 10:43 PM
  5. Is my pulley size correct
    By SleeperGS in forum General Tech Discussion
    Last Post: 08-06-2011, 11:21 AM
