Thread: Lower/drilled thermostat to lower trans temps?
Results 1 to 3 of 3
  1. #1 Lower/drilled thermostat to lower trans temps?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Is this a thing? I understand why people use them otherwise, but I've never heard of this reason. Also, a drill hole is free so it's no real cost over the 180deg thermostat.
    There is info that a 3800 can be "tuned" for a 180 or lower t-stat, but I'm unsure how that has anything to do with the transmission.
    Personally, I have much more faith in a low cost trans cooler (flex-a-lite, others) than drilling to achieve cooler trans temps. I'm interested in saving my trans by any means, but I also like heat in the MN winter. Kinda lost on this one.
    Thanks!
  2. #2 Re: Lower/drilled thermostat to lower trans temps?
    In theory if the coolant temp is lower the transmission temp could be lower as well. Though I never had a problem with transmission temps going on long road trips in the summer. If I saw it crack 170-175 on the open road that'd be few and far between. At a stand still it might rise some but always came right back down.
    Being tuned for a lower thermostat just means turning on the fan temps much lower than the factory 212/228ยบ temps. I'd say go ahead and drill 1 really small hole in the thermostat if you want to, it might run 5-10 degrees cooler while moving but nothing you'd noticed and you won't lose heat over it. Just run a real transmission cooler if you are seeing really high transmission temps.
  3. #3 Re: Lower/drilled thermostat to lower trans temps?
    May 2016
    MN
    Alright man, thanks for the clarification.
  1. Lower Control Arm or just lower ball joint
    By veener79 in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2014, 01:14 PM
  2. Lower T-Stat but same temps
    By gtpterp in forum General Tech Discussion
    Last Post: 04-23-2013, 06:26 AM
  3. Suggestions for running lower temps?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2011, 03:28 PM
  4. Hose temps- upper and lower (kinda dumb question I know)
    By diesan04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2008, 09:36 AM
