*update* so i opened the connector and pulled the pins (male and female) to the green wire. Couldnt find anywhere that sold just the pins so i clipped off the male end and stripped the wire. Once the wire was bipassed from the connector i placed wire in female pin and crimped it. I then wrapped some wire across male and female side and taped it up. Turned the key and she started.
I cracked the bottom starter terminal from over tightening so i will use some auto-electrical caulk to re-seal the starter but other then that all is well. Cost me a bit of time, a 12 pack of beer, $4 tape, and whatever the caulk costs.
Lesson learned: dont overlook the simple things. Idk how the wire got cut but it turned out to be a simple fix. All the info provided in this post helped me to diagnose the problem, so thank you to all that helped. It is much appreciated!
