Thread: knocking noise
Results 1 to 7 of 7
  1. #1 knocking noise
    Apr 2017
    CA
    2004 grand prix 3.8 engine knocking noise thought maybe rocker arm stud then maybeflex plate
  2. #2 Re: knocking noise
    That isn't enough to go off of, more details are needed.
    Is it all the time?
    Rise and fall with RPM?
    Glitter in the oil?
    Have a video?
  3. #3 Re: knocking noise
    St. Louis
    Canooter valve for sure. Pretty common.
  4. #4 Re: knocking noise
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    Knocking in the bottom end, cold, warm, idle.
    Need some more details...
  5. #5 Re: knocking noise
    May 2008
    Schuyler, NE
    It's most likely your dog's tail hitting the door when you say "good dog."
  6. #6 Re: knocking noise
    Apr 2017
    CA
    Quote Originally Posted by willdo View Post
    2004 grand prix 3.8 engine knocking noise thought maybe rocker arm stud then maybe flex plate
    Sorry wasnt done my wife sent anyway noise is all the time ive been a mechanic for 25years the only thing ive ever ran into like this turned out to be harmonic balancer was just running it past you guys who have been around these vehicles and idont have a dog , have only had a week was given car front valve cover off no pulled studs going after balancer
  7. #7 Re: knocking noise
    with a vid we can pretty much tell most time accurately what it is. we've heard it all from rockers to bottom ends to flex plates.
    do the old hold it at 2500 rpm and let it drop to idle, we're listening for the rod to be knocking on the fall of rpms, you kinda hear it bounce to its own beat.
    top end you get a misfire code sooner or later, but they stay in rhythm during that test.
    flex plates tend to knock at idle and go away driving some times. depends on how broken it is. sadly stock set ups break em. dont even need to be abusive either it seems.
  1. knocking noise when driving?
    By nickgpgt in forum General Grand Prix Discussion
    Last Post: 09-18-2013, 06:32 PM
  2. Knocking noise
    By TNTtransam in forum General Grand Prix Discussion
    Last Post: 09-14-2013, 10:13 PM
  3. Knocking noise in rear?
    By BlueGXP in forum General Tech Discussion
    Last Post: 10-17-2011, 08:38 PM
  4. Knocking Noise While Braking
    By jonrk7 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2010, 02:14 PM
  5. knocking noise. HELP
    By GMtuner29 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2010, 07:39 PM
