Nope, I sealed my long bolts with teflon tape as they go right into a water jacket.
I got lucky with using teflon tape, but there is a proper sealer you should use. If you look in the how to section you will find a write up for changing the water pump. The correct sealer is described there. Not a difficult job at all.
