Check all grounds. The symptoms you describe really point to either a bad ground or a bad ECU/BCM. Also, check all relays, could be a relay shorting as it gets hot.
Sent from my ASUS_Z00TD using Tapatalk
Today it sits at an Auto Electronics shop. I'll let you know the outcome. Thanks for your help. I'm at a loss.
