My son in his 97 GTP, recently rear ended another car. Most of the damage to the exterior was cosmetic, but it was a hard enough impact to cause the air bags to deploy.
I was able to locate an entire donor car for $75. I can use any part from it besides the motor.
When swapping out air bags, I plan to change out the control module under the passenger seat. Does the clock spring in the steering wheel need replaced too?
Are there any impact sensors anywhere? I could not find any once i ripped the front end apart. I hate to get it back together, then **POOF** when i connect the battery back up.
Are there any other components of the system i should swap out while i have the dash out?
