Thread: How can I measure fuel injector usage?
Results 1 to 15 of 15
  1. #1 How can I measure fuel injector usage?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Like title says how can I measure at what level or percentage my injectors are before they max out? I have dhp and torque pro.
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: How can I measure fuel injector usage?
    Watch injector duty cycle.
    Anything over like 90% is pretty much maxing them out.
  3. #3 Re: How can I measure fuel injector usage?
    with dhp you scan injector pulse width, "ipw"
  4. #4 Re: How can I measure fuel injector usage?
    Oct 2015
    But what's the max ipw?
  5. #5 Re: How can I measure fuel injector usage?
    Oct 2015
    I havent seen anything that said injector duty cycle in dhp or torque
  6. #6 Re: How can I measure fuel injector usage?
    Must be because they can't scan cool information like HP Tuners can or higher end scan tools.
    HPT can do duty cycle. In HPT, around 20-23ms on the injectors was getting close to that 90% on duty cycle. DHP does something goofy and puts those numbers into the thousands, so it's like 22,000ipw or some junk.
  7. #7 Re: How can I measure fuel injector usage?
    May 2008
    Schuyler, NE
    Pulse width by itself tells almost nothing, because it depends on rpm. Having a 20ms PW at 4500rpm is completely different than 20ms at 6500rpm.
    If you have dhp, I think you can create a parameter to measure idc.
    IDC=PW/(120/RPM)
  8. #8 Re: How can I measure fuel injector usage?
    Oct 2015
    IDC=PW/(120/RPM)
    Ok so IDC=PW/(120/RPM) is the parameter I should add?
    If i added this parameter how would I know what the "max" would be for my setup?
  9. #9 Re: How can I measure fuel injector usage?
    i was hitting 24,000 wot top of the rpms on a 3.2 pulley, installed 42's, now hits 16,000.
    3.2 is about the smallest you can go on stock injectors, but you would be right on the edge of maxed out.
  10. #10 Re: How can I measure fuel injector usage?
    Oct 2015
    Ya I have 42# but I'm also running e85 on a 3.4 setup and stock pump. But supposedly Arizona only has e54 which would obviously give me a little more head room with fueling which is why I have no idea where my injector duty cycle is at currently. I would assume it's getting up there and I'm in need of bigger injectors if I want to mod further
  11. #11 Re: How can I measure fuel injector usage?
    in that case your past max. you need 60's or so.
  12. #12 Re: How can I measure fuel injector usage?
    May 2008
    Schuyler, NE
    I used to run a 3.0 on stock injectors.
  13. #13 Re: How can I measure fuel injector usage?
    May 2008
    Schuyler, NE
    Quote Originally Posted by suitercrew View Post
    I really am not sure. It's been years since I needed that deeply with dhp. I'd have to play with it for awhile to figure it out.
  14. #14 Re: How can I measure fuel injector usage?
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Just go to google, and type in "Injector duty cycle calculator". The first link should be for Stealth 316, you just punch in your info (RPM and IPW) and hit calculate, boom, IDC.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  15. #15 Re: How can I measure fuel injector usage?
    Oct 2015
    Quote Originally Posted by 99GT2dr View Post
    Thanks man I will check that out when I get off work. I finally fixed my stupid dhp last night so I took a scan and after dropping to a 3.4 I'm seeing around 18.5 ipw at wot
  1. WTB 42.5lb fuel injector
    By jlgp2007nc in forum Wanted To Buy - Parts
    Last Post: 06-05-2014, 02:06 PM
  2. Fuel Injector #1 Squirting Gas
    By Mr D in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2014, 03:12 PM
  3. Fuel Injector Clips
    By Thompsju in forum Introductions/Noob Questions
    Last Post: 10-24-2013, 05:45 AM
  4. Fuel injector help !!!!
    By GTPAIELLO in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2012, 06:48 AM
  5. Fuel injector seating
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:42 AM
