Thread: Dome lights and radio won't shut off...
Results 1 to 10 of 10
  1. #1 Dome lights and radio won't shut off...
    SE Level Member Lawenforcer's Avatar
    Shelbyville, IL
    Hello all...Working on a 2000 GT. The dome lights and radio won't shut off. The radio wont shut off when key is out and open door. The passenger side door works. And the dome lights won't shut off, they are always on even with doors shut. Hoping for a quick fix on this. Thanks for the help.
    2000 Grand Prix GTP
  2. #2 Re: Dome lights and radio won't shut off...
    Ignition switch?
  3. #3 Re: Dome lights and radio won't shut off...
    Shelbyville, IL
    Only reason I am thinking it may not be ignition switch is cause the radio will shut off when ignition is turned off and passenger door opens up. I'm not sure how it all works with the door. Not sure if there is a switch in the door that can go bad and/or where it is even located or proper name of the part to possably find one to switch out.
    2000 Grand Prix GTP
  4. #4 Re: Dome lights and radio won't shut off...
    Shelbyville, IL
    Take it nobody has had this issue?
    2000 Grand Prix GTP
  5. #5 Re: Dome lights and radio won't shut off...
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Is there a switch in the door jamb? One of mine broke in the '97 Blazer and did that.
    It's like a $5 part I never replaced. I just pulled the bulbs and use the upper console lights.
  6. #6 Re: Dome lights and radio won't shut off...
    May 2016
    MN
    This might help. The location was my second guess if you can't see a door switch. http://www.chevytalk.org/fusionbb/sh...hp?tid/227256/
  7. #7 Re: Dome lights and radio won't shut off...
    Shelbyville, IL
    I messed around with it a little tonight. I unplugged the two plugs plugged into the door latch and it did not turn the lights off when door was closed. It's weird cause the open door is showing on the DIC when it is opened. So some kind of sensor is working. I am totally lost on this issue. Not sure what to check next. It's driving me crazy trying to figure it out...
    2000 Grand Prix GTP
  8. #8 Re: Dome lights and radio won't shut off...
    id try a ignition harness. they cause all sorts of funny crap. have seen this before too in older threads.
  9. #9 Re: Dome lights and radio won't shut off...
    Shelbyville, IL
    Thinking about the ignition. I am having problems with the tumblers in the cylinder or worn key. I have to jiggle the key to unlock to turn the key and I am able to pull the key out while running...
    Anyone think this could be part of my problem?
    2000 Grand Prix GTP
  10. #10 Re: Dome lights and radio won't shut off...
    nope, thats not part of the harness, you do need to take the tumbler out tho, so you can try lubing it up nice with lock graphite.
    http://sparkys-answers.com/2009/09/2...-changing.html the how to.
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. dome lights wont shut off 1998 grand prix gt 2 door 3800 II
    By simpson66 in forum General Tech Discussion
    Last Post: 02-13-2013, 11:20 PM
  3. 98 grand prix gt 2 door dome lights wont shut off
    By simpson66 in forum Introductions/Noob Questions
    Last Post: 02-13-2013, 04:02 PM
  4. dome lamp issues timer circut inop no dome lamp or floor lights
    By rgroffel in forum Introductions/Noob Questions
    Last Post: 12-24-2012, 08:56 AM
  5. Dome/Map lights
    By JCG's-GTP in forum 04+ Specifics
    Last Post: 02-22-2012, 09:11 AM
