Hello all,
Just received a 2004 GTP from a family member- has been sitting quite a while and many repairs were done. Most recently, the horn did not work and I was told it was a "wiring" problem that was fixed. On the drive home, I noticed that (1) the airbag readiness light remained on, (2) the cruise does not work and (3) the steering wheel audio controls do not light up or work. Does anyone think that it could be a "wiring" problem like the horn? Upon reading these forums, it appears that it very well may be the clockspring, but I would like to eliminate other possible causes before attempting to replace it or have the vehicle serviced. Ran an OBD-II scanner and no codes came up. I have checked many of the wires mentioned, but do not see any obvious problems. Any advice would be appreciated. If it is the clockspring (part number 26097600?), are there any non-OEM parts like Dorman, etc?
Lance
