Thread: Charing system failure
Results 1 to 11 of 11
  1. #1 Charing system failure
    Mar 2017
    Laramie, WY
    I have a 2006 Pontiac Grand GXP and I recently installed a new stereo. I noticed though that the radio and climate controls will often shut off and then turn back on. It also says 'charging system failure' or stability control and traction control inactive. It doesnt happen all the time though. Does anyone know what the issue might be?
    Thank you.
  2. #2 Re: Charing system failure
    GrandPrix Junkie
    St. Louis
    Did you use adapters to install the new stereo, or just cut the factory harness?
  3. #3 Re: Charing system failure
    Mar 2017
    Laramie, WY
    Quote Originally Posted by FordMan77 View Post
    I used adapters.
    Sent from my SM-G935V using Tapatalk
  4. #4 Re: Charing system failure
    SWPA
    It's either a hack install or just coincidence and your alternator is failing.
  5. #5 Re: Charing system failure
    Aug 2016
    CT/RI Border
    Was it JUST a stereo or a new system? Also, did your car have the Monsoon system?
    Sent from my ASUS_Z00TD using Tapatalk
  6. #6 Re: Charing system failure
    Mar 2017
    Laramie, WY
    Quote Originally Posted by nox View Post
    Just the stereo and it does not have Monsoon.
  7. #7 Re: Charing system failure
    SE Level Member Billycar11's Avatar
    Apr 2015
    Pa
    does it happen only after its warmed and then you turn the car off and back on? if so o think its an 04+ voltage regulator thing nothing to do with radio unless if pulls massive current
  8. #8 Re: Charing system failure
    SWPA
    Quote Originally Posted by Billycar11 View Post
    He's also getting flickering lights and other issues indicating its not just a false message. He needs to watch his voltage and see what is going on.
  9. #9 Re: Charing system failure
    Mar 2017
    Laramie, WY
    It just randomly happens while I'm driving. It never happens right after I turn it on.
    I just soldered all of the wires instead of using splicers and I'm about to take it on a pretty long trip. We'll see what happens.
  10. #10 Re: Charing system failure
    Apr 2015
    Pa
    http://www.grandprixforums.net/threa...-error-message read through some of the links it talks about the sensors that go bad or you could just have bad install or alternator
  11. #11 Re: Charing system failure
    Mar 2017
    Laramie, WY
    I soldered all the leads instead of using splicers and it seems to be working fine now. I took it on a long trip and it was fine. The voltage meter is reading lower now too (<15.0 usually).
  1. Charging system failure
    By michaelbig in forum General Grand Prix Discussion
    Last Post: 09-03-2016, 04:17 AM
  2. Charging System Failure
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 08-14-2014, 11:35 AM
  3. charging system failure
    By luckyg817 in forum General Grand Prix Discussion
    Last Post: 07-19-2014, 01:30 PM
  4. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  5. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
