Thread: Supercharger pulley belt question
Results 1 to 6 of 6
  1. #1 Supercharger pulley belt question
    Sep 2016
    Cleveland
    Hello! My supercharger pulley on my 97 gtp is squeeling, assuming replacing it should alleviate this issue?
    If so, is there anything i need to take into account if i get the 3 1/4th rather than the 3 1/2 pulley?
    I'd like to replace both belts as well while i'm at it.
    Thank you so much!
  2. #2 Re: Supercharger pulley belt question
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    You mean the supercharger pulley is smaller? I don't think you need a shorter belt until 3.2" or lower. If by 3 1/4, you mean a 3.4" it should be good with stock length.
    There might be a belt change pointer thread in the "Tips" section, iirc.
    How many miles are on that car? Has the supercharger oil ever been checked/replaced? "Squealing supercharger" doesn't sound good. Maybe once you get the belt off, give it a spin front and back by hand to see how it feels.
  3. #3 Re: Supercharger pulley belt question
    Sep 2016
    Cleveland
    One of the first things i did when i got the car (has 140k miles) was change the super charger oil.
    It doesn't sound like the actual supercharger is squeeling, it sounds like its coming from the belt /pulley area. I used a long rubber 1/2 inch hose up to my ear to try and locate the sound and it seems to be coming from there. Sounds like a typical belt/pulley squeek.
    I just looked up a video and it appears that you need a special tool to even replace it =/ any ways around that or types of tools one might have already you could use?
  4. #4 Re: Supercharger pulley belt question
    Kemmerer, Wyoming
    Look into changing the supercharger coupler
  5. #5 Re: Supercharger pulley belt question
    take the belt off, start the car see if its gone. if its gone, hand spin its idlers and tentioner pulleys, feeling for the one thats not spinning smoothly.
    if the sound is still there, take the other belt off, and same deal, run it, hand spin pulleys.
  6. #6 Re: Supercharger pulley belt question
    Sep 2016
    Cleveland
    sounds good will do.
  1. Where should you run the 6-rib supercharger belt on and 8-rib pulley
    By sseilmnop in forum General Tech Discussion
    Last Post: 02-03-2017, 01:47 PM
  2. Quick Question about Supercharger Belt
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2011, 07:01 PM
  3. belt size question for 2.8 pulley
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2009, 07:33 PM
