Thread: Boost problems
Results 1 to 2 of 2
  1. #1 Boost problems
    Mar 2015
    Western North Carolina
    Hey guys I have a 97 gtp an I'm having some boost problems it's only showing 4.4 lbs of boost on my gauge an my torque app an I can not figure out what is going on with it I've looked up the vacuum diagrams an it looks right an my bbv is hittin the set screw at the very bottom when reving the car an goin down the road an I have no leaks anywhere that I can find the only thing I can think to change now is the map sensor should that cause boost not to show if it's bad I'll list all my mods at the bottom thank you guys
    Xp hot cam
    ls7 lifters
    gen v sc
    gen v lim
    140 # valve springs
    fwi
    3.4 sc pulley
    speed daddy headers
    zzp 1.0 pcm
    ac delete
    all new internals pistons rings crank bearings cam bearings oil pump double roller timing set rods newer trans
  2. #2 Re: Boost problems
    May 2008
    Schuyler, NE
    It could be the boost bypass solenoid.
  1. Boost problems
    By BLACKanREDgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2015, 09:28 AM
  2. boost gauge problems
    By 04PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2012, 12:21 AM
  3. 99 Gtp boost problems
    By justrunningagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2012, 05:40 PM
  4. Autometer boost gauge problems
    By Kairocross in forum General Tech Discussion
    Last Post: 06-13-2011, 09:24 PM
  5. 2005 GTP Comp G Boost problems!
    By 05GTPcmpg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2011, 11:00 PM
