All,
I just came into possession of a 2000 GTP this weekend (174K miles). This car has been sitting for about a year. Interior is in real good shape (no rips or tears in leather, seat works) Now, the transmisison is gone (only have reverse). Hole in the resonator pipe (loud). No brakes (hard lines under the car are rusted thru) and the rotors/calipers/brakes are all junk. The belt and pulley were gone off the supercharger. Dead battery too. The inner rocker panels are junk (rusted out). So...here is where I started. Put on new belts and three new pulleys. Changed engine oil/filter. Changed air filter. Put on new radiator hoses (upper and lower) and new t-stat and gasket and new AF. So, I fired it up last night....purrs (or growls with hole in resonator). No smoke from engine/exhaust, idle around 800 RPM. I rev up the engine to hear/see if Supercharger is working. When I rev to 4K RPM's, I can see the boost gauge flicker a bar or two, but the engine sounds like it's misfiring or missing. I let off accelerator and it goes back to normal idle and engine response. Could this be the MAF sensor or EGR?
New to GM world (never owned one), new to SC.
Next biggest question is Should I cut bait and run (only have about 200.00 in it-guy owed me money, so he basically gave me this car for 100.00) I was planning on getting a new transmission from triple edge performance, but at this point I don't know if it is worth it. Plus I will have to do new brakes and hard lines all the way around.
What say ye?
And what genius at GM put the power steering in the back of the engine like that?
Thanks,
Steve
