Thread: Car has zero Electrical function
Results 1 to 5 of 5
  1. #1 Car has zero Electrical function
    SE Level Member Banana Hammock's Avatar
    Jun 2016
    Chicago
    I replaced my shifter assembly and now there is no electrical power going to my car. I checked all of the big fuses under the hood and they all seem fine. When I tap the negative battery cable to the battery i don't get any type of sparking. I hooked up the car to a battery charger to confirm power and still nothing. The car is completely dead. no lights or anything.
    I tried doing a voltage drop test and the meter didn't show a voltage increase.
    The car acts like it doesn't have a battery in it at all. No lights or anything.
    Any ideas?
  2. #2 Re: Car has zero Electrical function
    HUDSON
    Check your grounds.
  3. #3 Re: Car has zero Electrical function
    seems odd, the new one is plugged in and the cars plug and wires look ok right? cause they tend to break often.
    id try to plug in the old one, see if it comes to life. maybe the new one is the wrong year?
  4. #4 Re: Car has zero Electrical function
    Jun 2016
    Chicago
    I ended up trying this and swapped the old one back in and reconnected the battery and the car came to life and fired up. I put the "new" one back in then i reconnected the battery and the car came to life and fired up....so i am a bit clueless now as to what was going on.
  5. #5 Re: Car has zero Electrical function
    Jun 2016
    Chicago
    on a side note with the new one in place I can use the brake pedal to release the shifter instead of having to use the shift release button.
  1. Now with less white and more function.
    By machinegunsquid in forum Members Rides
    Last Post: 02-26-2016, 01:43 AM
  2. Genie 5 Lim porting for pcv function for i/c
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2011, 07:32 PM
  3. No up function on window
    By leetaylor in forum General Tech Discussion
    Last Post: 11-27-2010, 10:28 PM
  4. Broken function
    By TyroElite in forum Forum Bugs/Suggestions
    Last Post: 01-07-2008, 01:14 AM
  5. The Search Function Works!!! OMG!
    By Lawngoose in forum Off Topic Discussion
    Last Post: 12-27-2007, 11:07 PM
