Thread: Where should you run the 6-rib supercharger belt on and 8-rib pulley
Results 1 to 20 of 20
  1. #1 Where should you run the 6-rib supercharger belt on and 8-rib pulley
    Mercer, Pa
    6 rib belt with ZZP pulley you run in the middle!
    6 rib belt with Intense pulley you run with the belt on the inside (towards the charger)
    ZZP 8 pulleys are not the correct offset for ATI balances????? (1- rib off)
    Intense 8 rib pulleys are correct offset for ATI balances.
    What balance works with ZZP 8-rib pulleys?
  2. #2 Re: Where should you run the 6-rib supercharger belt on and 8-rib pulley
    SE Level Member bcmonzai's Avatar
    Surrey, BC
    PowerBond/Dayco balancers work with ZZP MPS.
    2000 GTP Silvermist Coupe - GMR Torsen, Cartuning trans pan, GMPP Lowering & Handling Kits, TOGs, Corsa, Racetronix, GXP Brakes, Eagle Alloy 077s, HPTuners, etc.
  1. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
