Thread: Subtle grinding sound
Results 1 to 4 of 4
310toumad Subtle grinding sound 01-31-2017, 03:04 PM
Keko Re: Subtle grinding sound 01-31-2017, 03:57 PM
310toumad Re: Subtle grinding sound 02-01-2017, 10:41 AM
Keko Re: Subtle grinding sound 02-01-2017, 11:44 AM
  1. #1 Subtle grinding sound
    Sep 2015
    IL
    Sounds almost like a bad pulley to me, but I only hear the noise when the car is moving. Its relatively quiet, but becomes a lot more noticeable when the engine hits 2000 RPM. Obviously something spinning fast and sound seems co-dependent on engine RPM. However when I put it in park, rev the engine to over 2000 and I hear nothing. Bad CV joint or wheel bearing? I don't hear anything when turning, and its barely audible when cruising steadily.. just when I accelerate. I did notice some grease leaking out of the driver's side CV boot recently, but not a ton. Could that joint be going bad?
    I have yet to take off the belts and spin the pulleys by hand. I have a stethoscope I can use, but if the noise isn't there when the car is being revved at idle can I rule it out being a pulley?
  2. #2 Re: Subtle grinding sound
    SE Level Member Keko's Avatar
    Nov 2016
    California
    Sounds like a bad wheel bearing. You can check wheel bearings in about 3 minutes just by jacking it up and seeing how much vertical is on the wheels. Do a quick youtube search.
    I have a bad CV joint that I am replacing soon and the symptom is shaking at 65+mph with light acceleration. It makes a couple odd noises every once in awhile but I don't think that's the issue you have.
    [Daily] 2002 GTP 40th Ann - FSIC, dp+plog, 3.3", ported LIM, HAI, front+rear sway bars, poly mounts, zzp tune for now :/
    [Fun] 2012 mazdaspeed3 - dp, 3" intake, FMIC, HPFP, Custom tune, lots of other goodies
  3. #3 Re: Subtle grinding sound
    Sep 2015
    IL
    The only thing that makes me question if its a wheel bearing is wouldn't it be audible when I get up to speed? It only gets loud while accelerating, but once I reach a constant speed you can't really hear it. I could accelerate from 0-30, hear the noise, but once I'm cruising at 30 nothing. Same thing if I were to go from 45-65, etc. But again zero noise when I rev the engine sitting in park. I guess I'll raise it up and spin the wheels by hand and see if I hear any gritty/grinding noises.
  4. #4 Re: Subtle grinding sound
    Nov 2016
    California
    Maybe someone else can chime in. Suppose it could be a bad CV, but it's weird that you would only have the noise at lower speeds? My passenger CV is bad and shakes above 65mph but only if I am accelerating. Coasting at 65 is not noticeable.
  1. a grinding sound
    By chris99gtp in forum General Tech Discussion
    Last Post: 08-24-2012, 08:30 PM
  2. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  3. Grinding sound
    By gpgt04 in forum General Tech Discussion
    Last Post: 12-18-2009, 09:18 AM
  4. Grinding Sound
    By Strype in forum General Tech Discussion
    Last Post: 09-02-2009, 01:15 PM
  5. bad grinding sound
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2009, 04:53 PM
