Thread: Car will not shift out of park
Results 1 to 7 of 7
  1. #1 Car will not shift out of park
    SE Level Member Banana Hammock's Avatar
    Jun 2016
    Chicago
    My 2000 gtp will not shift out of park. When I press the brake pedal and try to change gears it will not shift and I hear a buzzing noise above my legs under the dash.
    I looked through this thread a bit but I didn't see anyone mention hearing the buzzing noise. http://www.grandprixforums.net/threa...-stuck-in-park
  2. #2 Re: Car will not shift out of park
    it could be a busted wire to the shiftier under the console. pretty common. id start there. vid in that link shows it pretty good
  3. #3 Re: Car will not shift out of park
    Jun 2016
    Chicago
    I plan on checking out the wiring harness. I just wasn't sure if the buzzing might point to something different.
    thanks
  4. #4 Re: Car will not shift out of park
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by Banana Hammock View Post
    thanks
    I had the same thing happen to my GP a couple of years ago. It was a couple of broken wires from the wiring jacket that plugs into the shift solenoid. I cut all the wires and soldered some extensions on all the wires then wrapped it all up w/electrical tape. The wiring jacket has a big bend before it plugs into the solenoid and that's where the wires break.
    gpbastard
  5. #5 Re: Car will not shift out of park
    Jun 2016
    Chicago
    I went out and looked at it for a bit but it is a bit too cold outside.
    I took a short video of the sound i am hearing when i press the shift button in.
    https://vimeo.com/200593987
  6. #6 Re: Car will not shift out of park
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    Probably a broken wire at the BTSI switch harness at the base of the shifter.
  7. #7 Re: Car will not shift out of park
    Topeka, KS
    I had a similar issue but my shifter button stayed pressed in. I replaced the shifter handle and have had no issues since.
    Sent from my VS990 using Tapatalk
  1. Car Won't Shift Out Of Park
    By jimmysmalls in forum General Tech Discussion
    Last Post: 07-21-2016, 09:43 PM
  2. Can't shift out of park
    By disallow in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-08-2014, 03:30 PM
  3. Won't shift out of park
    By AKGTP19 in forum General Grand Prix Discussion
    Last Post: 11-12-2013, 09:05 PM
  4. Can shift from park with the car off
    By camopaint0707 in forum General Grand Prix Discussion
    Last Post: 07-19-2013, 06:13 AM
  5. cant shift out of park
    By gtpenthusiast in forum General Tech Discussion
    Last Post: 07-12-2013, 07:58 AM
