Thread: Fuel pressure drop
Results 1 to 8 of 8
  1. #1 Fuel pressure drop
    Dec 2016
    OHIO
    Hello everyone,
    I have a 00 GTP that is loosing fuel pressure, starts in the upper 40's and drops to 0 in 30 to 45 sec.
    Has new pump and filter, injectors test at 12 ohms, fuel reg test good. both relays test good.
    has anyone come across this before?
    any ideas would help, thanks so much everyone.
    Have a great New Year!
  2. #2 Re: Fuel pressure drop
    it dropping car running? or after its turned off?
  3. #3 Re: Fuel pressure drop
    Dec 2016
    OHIO
    running,
    but same with key on eng. off
  4. #4 Re: Fuel pressure drop
    Dec 2016
    OHIO
    running and koeo
  5. #5 Re: Fuel pressure drop
    does it drive ok? or is it stalling out on ya? they need 42 or more to run.
    if it runs id test the gauge on another car, maybe its bad.
  6. #6 Re: Fuel pressure drop
    Dec 2016
    OHIO
    I belive I have found the problem
    The relay on the frame rail is bad
    No one has one around here not even the dealer
    Waiting till Tuesday until it comes in.
    The car would start and stall, I bought a weak fuel pump too I only have 42 psi.
    But I have the fuel pump in high and it's running know. Thanks for the help though.
    Hopefully this relay I'm waiting on will fix it
    Let you know Next week. Have a great and safe new year
  7. #7 Re: Fuel pressure drop
    Antioch, IL
    resistor? no need to run it, twist the wires together and go about your day.
    2009 Challenger SRT8
    Expert at being gay.
  8. #8 Re: Fuel pressure drop
    do this.
  1. Drop Fuel Tank
    By roundbox52 in forum General Tech Discussion
    Last Post: 07-15-2023, 08:43 PM
  2. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  3. Hi pressure low pressure fuel connectors , i lost the springs that go inside. help
    By Hardonyomom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2014, 09:31 PM
