Thread: L36 engine swap
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: L36 engine swap
    TDCRacing
    Guest
    Yes the gen 5 will fit on the series 2 engine. I believe you have to use the LIM from a series 3 though.
    For what you stated above that will run at least 1700 dollars.
  2. #22 Re: L36 engine swap
    SE Level Member themagicdustman's Avatar
    Jan 2009
    Baldwinsville, NY
    thanks a lot. i think im gonna go with the top swap based on all the imput. it'll be cheaper not buying another engine. mine only has 125k on it anyway. you guys def. know your stuff, thanks a lot for all the help. definitely a good thread to get introduced to the site on.
  3. #23 Re: L36 engine swap
    TDCRacing
    Guest
    Well, Glad we could help. If you need anything else be sure to let us know.BTW if you don't already know you'll need a wiring harness from a 97-03 gtp and a pcm to make everything work right.
  4. #24 Re: L36 engine swap
    Jan 2009
    Baldwinsville, NY
    okay. upgraded axles too iirc? or is that not necessary?
  5. #25 Re: L36 engine swap
    TDCRacing
    Guest
    I think one of the axles in the non HD tranny is shorter in length. But i would double check on that.
  6. #26 Re: L36 engine swap
    Jan 2009
    Baldwinsville, NY
    im most likely putting a 4t65e-hd on there as well. it should be okay for a little while with the stock trans, but def. getting an hd.
  7. #27 Re: L36 engine swap
    Jan 2009
    Baldwinsville, NY
    do the mods for the L36 ss m90 kit fit both gen 3 and gen 5? theyre not real specific on the site.
  8. #28 Re: L36 engine swap
  9. #29 Re: L36 engine swap
    Jan 2009
    Baldwinsville, NY
    does anyone know if its possible for them to send a gen v?
  10. #30 Re: L36 engine swap
    TDCRacing
    Guest
    You would be better off getting one used. ZZP charges what? 700 for a gen 5? I just sold a ported and polished one for like 450 shipped. Rebuilt too...And it only had 43,000 miles on it to begin with.
  11. #31 Re: L36 engine swap
    Barksdale AFB, LA
    Quote Originally Posted by themagicdustman View Post
    As long as you don't do burnouts with your non-HD, it'll hold up just as well as the HD will. The only significant difference is the differential, which only matters during a burnout. The pinion shaft is thicker and will resist scoring from one wheel burnouts better. But, even it will fail eventually.
    Moral of the story, don't do burnouts. Especially if you don't know how to get both wheels spinning.
    2009 Subaru Impreza WRX STI
  1. could a top swap on my n/a 3.8 v6 engine fix current problems?
    By GEMINIokc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 08:59 AM
  2. engine swap question!!!!
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 12:27 PM
  3. Engine swap
    By BankRupt in forum Off Topic Discussion
    Last Post: 07-19-2008, 11:06 AM
  4. engine swap
    By 3800John in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-03-2008, 02:53 PM
  5. Swap 3.8 (L67) into 3.1 engine compartment?
    By jerricho in forum General Tech Discussion
    Last Post: 05-17-2008, 12:07 AM
