Thread: Service engine soon light
Results 1 to 11 of 11
  1. #1 Re: Service engine soon light
    Oklahoma
    My wife has a 1996 Jeep as well and I dont think I can retrieve the codes in the way you mentioned. However, 1996 was the first year for ODB-II and some vehicles that year had ODB-II and some still had the older ODB-I. The ODB-I systems you could retrieve in the way you mentioned or using a shorting clip on the ALDL interface connector.
  2. #2 Re: Service engine soon light
    SE Level Member the955iman's Avatar
    Feb 2009
    Griffin, GA
    Mine is 96 Cherokee Sport, aka. The Turd.
  3. #3 Re: Service engine soon light
    Feb 2009
    Griffin, GA
    It's also worth noting that the car shows no other symptoms. Runs fine, idles fine, all other gauges are good. Just came on while sitting traffic.
  1. Engine light came on what to do?
    By jasonball in forum General Tech Discussion
    Last Post: 12-03-2008, 03:44 PM
  2. *ERROR CODE INSIDE* Installed new PCM - Service engine light is on
    By Freebeer187 in forum General Tech Discussion
    Last Post: 11-23-2008, 07:05 PM
  3. check engine light
    By cboth686 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2008, 08:48 PM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Service Engine??
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 11:55 AM
