Thread: 1999 Grand Prix Hazard light problems
Results 1 to 10 of 10
  1. #1 1999 Grand Prix Hazard light problems
    Oct 2016
    Charlotte, NC
    Hello all,
    My 1999 Grand Prix is having a hazard light issue that's got me perplexed. I have checked ALL exterior lights, running, brake, back up, left and right turn etc and they all work properly, however when I turn my hazard lights on all flash correctly except for the right front(even though that light works fine as a right turn signal).
    I changed the flasher unit with no change, however I am curious if this year model has a turn AND hazard flasher? Any help would be GREATLY appreciated as I can't find a similar situation anywhere on the net and I need to get it inspected.
    Thanks
  2. #2 Re: 1999 Grand Prix Hazard light problems
    Omaha, NE
    What is that bulb doing? Flashing really fast, just lighting up and not flashing, or not turning on at all?
  3. #3 Re: 1999 Grand Prix Hazard light problems
    Oct 2016
    Charlotte, NC
    Nothing at all, and the corresponding dash light also does nothing. Both work normal when using as turn signal.
  4. #4 Re: 1999 Grand Prix Hazard light problems
    could be the multi switch, the hazard button is part of it.
  5. #5 Re: 1999 Grand Prix Hazard light problems
    Quincy, Mass
    My thoughts also
    No more GP 04 Impala SS Indy:
  6. #6 Re: 1999 Grand Prix Hazard light problems
    Oct 2016
    Charlotte, NC
    You would think if it was the switch it wouldn't work at all. To be clear when the hazard button is pushed ONLY the RF light does not flash all the other corners of the car are fine. And also to clear something else up, there is only one flasher unit right? That controls the blinker and hazard functions?
    Thanks for the ideas so far.
  7. #7 Re: 1999 Grand Prix Hazard light problems
    Jan 2014
    AR
    Probability is high that you just have a bad bulb. Remove your side marker / turn signal lamps and try new bulbs.
  8. #8 Re: 1999 Grand Prix Hazard light problems
    Oct 2016
    Charlotte, NC
    All the bulbs have been changed and still doing the same thing. So everyone think it's the switch? I really don't want to change it lol
  9. #9 Re: 1999 Grand Prix Hazard light problems
    its not hard to change, trickiest part would be the plastic cover and not breaking it. the rest is easy.
  10. #10 Re: 1999 Grand Prix Hazard light problems
    Jul 2010
    Coquitlam,BC,Canada
    MFS as mentioned. It has contacts in it that are probably worn out. I tried fixing the one in my T-Bird, and everytime I messed with it, something else started or stopped working. Very finicky. I just swapped in a new one and moved on to the next problem.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. 1999 Grand Prix Light Gages switch
    By Loftus1995 in forum Visual/Body Modifications
    Last Post: 06-24-2014, 12:23 AM
  2. New (to me) grand prix with lowbeam light problems.
    By gdavison86 in forum General Grand Prix Discussion
    Last Post: 01-21-2013, 11:35 PM
  3. 1999 Pontiac grand prix problems
    By dkeener in forum Introductions/Noob Questions
    Last Post: 10-25-2010, 08:53 PM
  4. having problems removing water pump on 1999 grand prix gt 3.8L, series 2
    By RyanGerner in forum Introductions/Noob Questions
    Last Post: 08-17-2010, 09:30 PM
  5. 1999 Grand Prix GTP rear passenger window & locking problems
    By RYANPOWERSMAIL in forum General Tech Discussion
    Last Post: 05-24-2009, 03:51 AM
