Thread: Stalled, Wont start again, Help please
Results 1 to 17 of 17
  1. #1 Stalled, Wont start again, Help please
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    98 gtp, stalled a few times over last month. started back up within a reasonably time each time. always when driving it stalls.
    first thing i thought was CKPS. changed that today. Still turns but no start. i hear fuel pump prime. changed that last month anyways.
    It did throw a P0102 Mass air low Low circuit. I didnt think a bad MAF would keep the car from starting. i did take it out and clean it and change with another one i had. Not sure if both are bad or what but i would think it would still start even with bad MAF. Help me. Where do i look next?
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  2. #2 Re: Stalled, Wont start again, Help please
    check fuse #21 marked ign, thats the maf fuse. the p0102 code is a low or no voltage.
  3. #3 Re: Stalled, Wont start again, Help please
    Apr 2014
    Chicopee,MA
    Just checked all fuses. all look good. Battery and Alt are new within last month too.
    Can a MAF really keep car from starting? Ill go get a new one if we think thats it. but i just want to be sure befor i spend any more $ on this car.
  4. #4 Re: Stalled, Wont start again, Help please
    could be the maf. unplug it, then try to start the engine up.
  5. #5 Re: Stalled, Wont start again, Help please
    Apr 2014
    Chicopee,MA
    I did that, still nothing.
  6. #6 Re: Stalled, Wont start again, Help please
    make sure you have fuel and spark then. and the air filters not clogged shut too. if you still have a air box. mice are bastards.
  7. #7 Re: Stalled, Wont start again, Help please
    Apr 2014
    Chicopee,MA
    Open Cone, cold air intake box. i did think it was the air. so i took off the whole filter and everything but still nothing. How can i check the fuel and spark?
  8. #8 Re: Stalled, Wont start again, Help please
    shrader valve on the rail, its got a fat black cap.
    spark, take a plug wire off the coil and prop it a inch over the coil, then crank it, watch for a blue spark to jump to the wire.
  9. #9 Re: Stalled, Wont start again, Help please
    Apr 2014
    Chicopee,MA
    checked the fuel, spits out so i think good. I took the plug off at coil and leave chilling a inch or so away. tried to crank car. didnt see anything. but not sure if i did it right. is there another way to test spark?
  10. #10 Re: Stalled, Wont start again, Help please
    spark tester, it plugs into the plug wire and will flash if theres spark.
  11. #11 Re: Stalled, Wont start again, Help please
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I've had a maf leave me stranded had to have my car towed a couple years ago. I went to the gas station everything was fine got gas went to go start it and nothing it tried to start but then nothing I could smell gas bad no check engine or anything. I had my buddy scan it with his snap on computer the maf was literally just dumping alot of fuel into the cylinders.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  12. #12 Re: Stalled, Wont start again, Help please
    Apr 2014
    Chicopee,MA
    checked the spark plugs with tester and no spark on them. Leaves me to think ECM??
  13. #13 Re: Stalled, Wont start again, Help please
    very possible, if you got a parts car there swap it. na, sc, all the same icm.
    or you can have it tested at a parts store, but they do tend to test good when bad. jy would be the cheap way to get a new one, new they are not cheap at all.
  14. #14 Re: Stalled, Wont start again, Help please
    Jul 2015
    Jamestown, NY
    I think I have a ICM laying around if you can't find one.
  15. #15 Re: Stalled, Wont start again, Help please
    Apr 2014
    Chicopee,MA
    Swaped out the ICM from my other GTP and is started right up! Thank you scotty and tonkin for the help! How much for your extra ICM?
  16. #16 Re: Stalled, Wont start again, Help please
    good to hear.
  17. #17 Re: Stalled, Wont start again, Help please
    Jul 2015
    Jamestown, NY
    I actually have 2 of them the one the plastic where the plug goes in is cracked there's a little chunk missing. I think that is why the guy gave me 2 of them I can send you pictures. I got them a couple years ago with my top swap I bought off a guy from a running Buick regal with 80,000 miles and he gave me alot of things from the car I didn't need. Since they are the same ICM for both N/A and S/C I never changed mine. I'm going to be honest I'm not 100% sure they work but they should. Everything else he sent me was in really good shape and worked the supercharger coating was perfect along with the injectors and everything. So it's up to you just trying to help people out on here when I can because people have helped me out.
  1. 2002 GTP Stalled at Cold Start; Now Won't Start at All
    By Nick8478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2015, 04:51 PM
  2. Engine Stalled And Now Will Not Start...
    By deltatango in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2013, 06:54 AM
  3. Topped swapped 06 GP now wont start and scan tool wont comm with ECM
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2013, 08:36 AM
  4. 2000 GTP Stalled and Won't Start
    By patori in forum General Tech Discussion
    Last Post: 01-21-2013, 05:18 AM
  5. 98 gtp 3.8L sc...stalled wont start...
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2011, 05:52 AM
