Thread: P0133 o2 sensor slow response?
Results 1 to 20 of 28
  1. #1 P0133 o2 sensor slow response?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Just pulled this pending code curious what it might be if uts a common code for our cars. I would assume it could be a bad o2 sensor or maybe exaust leak??
    Sent from my LG-H811 using Tapatalk
  2. #2 Re: P0133 o2 sensor slow response?
    Oct 2015
    I also was just watching my stft and ltft they lock in at -2 at wot and are within 5% just driving around but at idle my ltfts are -10 to -15!! Wow!?
  3. #3 Re: P0133 o2 sensor slow response?
    https://www.obd-codes.com/p0133 time for a new o2. or its wires are messed up maybe.
  4. #4 Re: P0133 o2 sensor slow response?
    Oct 2015
    Well im going to check for an exaust leak and if i have a leaky injector before i go spending money on a new sensor i would assume its the original sensor since i got the car with 90k on it now has 104k
  5. #5 Re: P0133 o2 sensor slow response?
    Oct 2015
    Could a bad o2 cause kr
  6. #6 Re: P0133 o2 sensor slow response?
    yes.
  7. #7 Re: P0133 o2 sensor slow response?
    Oct 2015
    I guess i better get on it then i had it tuned on 16* timing with no kr and now im seeing anywhere for 1-3.5 throught wot
  8. #8 Re: P0133 o2 sensor slow response?
    hell yeah then lol it talks to the maf, so if its getting bad info, fueling will get screwed up.
  9. #9 Re: P0133 o2 sensor slow response?
    Oct 2015
    Its just weird cause my fuel trims are pretty on point driving and at wot but at idle there all f*ckerd up
  10. #10 Re: P0133 o2 sensor slow response?
    hangover park IL
    the o2 is a "trusted" sensor. the pcm automatically assumes its fine and that ~450mv is stoichiometric AFR. problem is that over time it "skews" and no longer reads correctly, so the pcm supplies incorrect amounts of fuel.
    really they should be changed about every 50k or so. do not use bosch, use denso/ngk/Delphi sensors only
    ~James~ Psychotic Gearhead
  11. #11 Re: P0133 o2 sensor slow response?
    Oct 2015
    Idk when i watch live data it seems to function prettt normal though
  12. #12 Re: P0133 o2 sensor slow response?
    if you got a code for it and your trims are messed up now, change it. this is a no brainer really. and if they are over 50,000 miles old, they should be changed anyways.
  13. #13 Re: P0133 o2 sensor slow response?
    Oct 2015
    Okie should i reset the trims after i put the new one in?
  14. #14 Re: P0133 o2 sensor slow response?
    you can, or they will re learn anyway if you dont.
  15. #15 Re: P0133 o2 sensor slow response?
    hangover park IL
    resetting the adaptives is better than letting it do it as a reset puts it into "fast learn" mode
  16. #16 Re: P0133 o2 sensor slow response?
    Oct 2015
    I figured as much. Thanks guys hopefully it fixes it. Ill make sure to look for an exaust leak while im down there too. I still have the original flex on my sd headers
  17. #17 Re: P0133 o2 sensor slow response?
    Oct 2015
    Holy **** i ran a scan driving home on my lunch break and whenever i give part throttle loke 15-30% my fuel trims are hitting -20 if not more and im getting spokes 3-4* of kr when im not even in boost what the heck? Im running so rich its causing kr
  18. #18 Re: P0133 o2 sensor slow response?
    Oct 2015
    Im curious about how you tellvif an ect sensor is bad as well cause torque pro is saying my temp is 190 but the gauge on the dash is just a hair above 160 i dont know if that means anything?
  19. #19 Re: P0133 o2 sensor slow response?
    means the obd2 scan is the right temp. cluster is never dead on or even close.
  20. #20 Re: P0133 o2 sensor slow response?
    Oct 2015
    Ok i figured it didnt mean anything. But ok thanks guys ill try to get that o2sensor replaced today or tomorow and let you guys know what happens
  1. P0133 97 Buick Lesabre
    By Impala131 in forum General Tech Discussion
    Last Post: 03-30-2016, 02:39 AM
  2. Mid range foot response
    By themantis in forum General Grand Prix Discussion
    Last Post: 03-29-2016, 09:43 PM
  3. Steering response
    By Aeroheadcww in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2011, 07:19 AM
  4. Troubleshooting Help! p0133/p1133 Slow response o2
    By Lawngoose in forum General Tech Discussion
    Last Post: 12-29-2009, 08:39 PM
  5. code p0133
    Last Post: 04-28-2009, 06:10 PM
