Thread: best way to remove front sway bar?
Results 1 to 11 of 11
  1. #1 best way to remove front sway bar?
    Sep 2015
    Lansing, Michigan
    02 gp gt.
    I have a torch and impact wrench. Also have wrenches and adjustable wrenches. Just no ratcheting wrenches.
    Can I remove the tie rod end and just pull the bar out or do I have to drop the cradle on one side? i'm really trying to avoid having to drop it lol. will removing the tie rod end force me to get an alignment afterwards?
  2. #2 Re: best way to remove front sway bar?
    You can pop the tie rod without needing an alignment, just don't spin the inner tie rod or anything.
  3. #3 Re: best way to remove front sway bar?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    i had success getting the front end up as high as possible. Didn't disconnect the tie rod. Getting a thicker GMPP bar in there was crazy but it worked.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  4. #4 Re: best way to remove front sway bar?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Yep. just need to get it angled correctly. kinda of PITA. You'll probably need a 15 MM ratcheting wrench for the inner bushings.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  5. #5 Re: best way to remove front sway bar?
    popping a tie rod and dropping the sub frame 2 inches will save you a ton of time and hassle. of one the brake lines pass the d/s sway bar bushing cap rear bolt, if your lines are rusty looking you dont want to play with them by leaning on then with a socket and causing them to leak. plus its tight to get that one bolt off.
    this pic the frame is dropped a lot for a rack swap, but you can see how th elines match up to the sway bar cap.
  6. #6 Re: best way to remove front sway bar?
    Sep 2015
    Lansing, Michigan
    is the steering intermediate shaft a pita to reconnect if it becomes disconnected?
  7. #7 Re: best way to remove front sway bar?
    Aug 2016
    MN
    Quote Originally Posted by tom5170 View Post
    They can be, although they are designed to be difficult to disconnect. I've never had one get accidentally disconnected. I second dropping the rear of the subframe. Pretty sure I didn't disconnect the steering shaft when I installed mine, but had to drop the frame to reinstall the new bar, there was just no other way for me.
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  8. #8 Re: best way to remove front sway bar?
    Apr 2014
    CT
    I wouldnt recommend not disconnecting the steering when dropping the rear of the subframe. It is a pita to get back on but make sure to tie down the steering wheel. You need 11mm socket and a long extension to get the pinch bolt out. Its not that hard, you may fiddle with it for a long time before it finally just slips back together properly, I think what makes it hard to reassemble is your fighting to keep the rubber dust cover up out of the way. i've done it 3 times so far and I would rather disconnect the steering pinch bolt than try to get the two ps rack to subframe bolts out.
  9. #9 Re: best way to remove front sway bar?
    Nov 2011
    NY
    I've found that exiting through the passenger side is the o OY way to get the sway in/out, especially the oversized ones, without taking all that stuff apart. But it is easier if you pop control arm/ball joint to move that out of the way. You want Energy Suspension Poly's all around with that as well, get the bracket with the zerk fitting so you can grease the bushings too... : )
    Good Luck!
  10. #10 Re: best way to remove front sway bar?
    Quote Originally Posted by paedbo View Post
    when you drop the frame for this you only drop it two inches, no need to un do the shaft, it will open open up fine and retract.
  11. #11 Re: best way to remove front sway bar?
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    I didn't drop the subframe at all on my 04, just popped both outer tie rods out of the knuckle and used a little bit of wire to hold then up out of the way.
    It was a bit of a pain to get the original sway out, lots of twisting this way and that, but it came out the driver's side just fine.
    I put the Dorman in through the passenger side, slowly so not to catch any lines or harnesses, and it went in easier than the old one came out.
    I had to use a regular open end wrench for the driver's side bushing bracket rear bolt, but the rest of them came out/went in easy with a 3/8ths ratchet.
    Didn't touch the rack, steering shaft, brake lines or subframe bolts.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  1. Broken front sway & alignment ? Also sway bar recommendations..
    By Exile in forum General Tech Discussion
    Last Post: 10-14-2016, 12:24 PM
  2. front sway bar
    By Toasty in forum General Tech Discussion
    Last Post: 03-23-2013, 12:34 PM
  3. GMPP front and rear sway w/ front STB
    By FordMan77 in forum General Grand Prix Discussion
    Last Post: 10-31-2012, 03:04 PM
