Thread: Cooling fans only come on with ac
Results 1 to 10 of 10
  1. #1 Cooling fans only come on with ac
    Oct 2016
    Chesapeake
    Engine temp ran up to 2 notches from red in stop and go traffic one day. As an experiment I parked car and let idle, same thing, checked fans, neither one on. Turned AC on and both come on cooling car right down to about 180. Figuring it's the engine temp sensor, any thoughts? Could it be one of the 3 fan relays? Thanks for any advice!
    Kevin
  2. #2 Re: Cooling fans only come on with ac
    sounds like the temp sensor, they fail all the time.
  3. #3 Re: Cooling fans only come on with ac
    Oct 2016
    Chesapeake
    Gonna replace and will give update, thx
    Kevin
  4. #4 Re: Cooling fans only come on with ac
    St. Louis
    FYI- get an OEM GM sensor for it. The ones at the parts stores seems to have a high failure rate, and some are even bad out of the box. Might be $10 more at the dealer but worth it in the end. I went through 2 "new" sensors before I finally went to a dealer and got a GM one. After that the temp readings were where they should be.
  5. #5 Re: Cooling fans only come on with ac
    Oct 2016
    Chesapeake
    I agree, price range 7 to 15 bucks, went with AC Delco($15) from RockAuto.com
    ACDELCO 213815 {#10096181} Sensor GM Original Equipment Info
    3 blade terminal; W/IND SW; MATING CONNECTOR WITH LEADS USE PT1825
    Gonna keep AC on til it arrives and we'll see what happens, thanks for input!
    Kevin
  6. #6 Re: Cooling fans only come on with ac
    Oct 2016
    Texas
    I bought mine today at a dealership for $40.
  7. #7 Re: Cooling fans only come on with ac
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    Quote Originally Posted by Diegozr1 View Post
    I bought mine today at a stealership for $40.
    fixed that for ya.
  8. #8 Re: Cooling fans only come on with ac
    Oct 2016
    Texas
    [QUOTE=JamesIvey24;1449671]fixed that for ya.[/QUOTE
    I'm putting it tomorrow. I'll update
  9. #9 Re: Cooling fans only come on with ac
    Oct 2016
    Texas
    Quote Originally Posted by JamesIvey24 View Post
    fixed that for ya.
    Yup new sensor fixed the problem!!
  10. #10 Re: Cooling fans only come on with ac
    Oct 2016
    Chesapeake
    Same here, easy fix, 5 min.
    Kevin
  1. cooling fans
    By GXPrunner06 in forum 5.3L V8 (LS4)
    Last Post: 09-22-2013, 04:16 PM
  2. cooling fans
    By polarisdescent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-07-2012, 04:28 PM
  3. cooling fans on 90 G.P.
    By TIMS TURBO in forum General Tech Discussion
    Last Post: 05-01-2012, 06:34 AM
  4. cooling fans always run
    By jaxso6 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2011, 08:33 PM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
