Thread: 2005 GT passenger window switch R & R help
Results 1 to 2 of 2
  1. #1 2005 GT passenger window switch R & R help
    Feb 2009
    West Michigan
    I need to replace an intermittent front passenger side window switch in my 05 GT. The window goes down, sometimes it goes up but not usually. Does anyone know if I need to remove the interior door panel to get at the switch? Or is there a trick to removing the trim piece only around the switch? It appears as though the switch plate is installed from the back side of the door panel. I'm not realy excited about ripping the interior door panel off if there is a simpler way of gaining access to the switch.
  2. #2 Re: 2005 GT passenger window switch R & R help
    Donating Users
    Deland, IL
    the switch panel should pop out of the panel
  1. bad window switch help (GTP)
    By IndeedSS in forum General Tech Discussion
    Last Post: 07-26-2009, 11:23 PM
  2. run in with a 2005+ Audi A8L W12
    By fst in forum Track Sessions and Kills
    Last Post: 05-06-2008, 09:00 PM
  3. 2005 Gtp Rims
    By GTX in forum Tires & Wheels
    Last Post: 04-12-2008, 10:51 AM
  4. window switch trim
    By kingd44 in forum The Rant Forum
    Last Post: 03-23-2008, 08:38 PM
