Thread: Not sure what the true issue is.
Results 1 to 7 of 7
  1. #1 Not sure what the true issue is.
    Sep 2016
    Johnson city
    So this issue started about a week ago. When I start the faggot I get 5+ messages on the dic and I cannot seem to find what the issue is. Stability control off, Abs System off, Traction control off, service stabiblty control, service abs system, service traction control. And sometimes I even get variable effort steering disabled. Unplugged battery no effect. checked hubs they all seem to check out fine. And from what I see my abs unit is fine. Any ideas guys?
  2. #2 Re: Not sure what the true issue is.
    Dec 2012
    troll land
    have you checked the plug on the rack?
  3. #3 Re: Not sure what the true issue is.
    Sep 2016
    Johnson city
    No I have not. Can you give me an idea where the plug is?
  4. #4 Re: Not sure what the true issue is.
    its a abs issue, get it scanned for abs codes, no the free scanner at the parts store wont work, you'l need to hit a shop up that has a tech 2 or snap on scanner, or pony up and buy a abs scanner.
  5. #5 Re: Not sure what the true issue is.
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    That blue plug connects to the harness coming off the steering rack, for the Magnasteer.
    You could also check the connectors at the hubs, sometimes the wiring gets chewed up a couple feet away from the connector.
    Also check the connections at the ABS module and the BCM, black box behind the driver's side dash next to the door...
    Outside of that, sounds like a bad ABS module, you can get them rebuilt for about 100 bucks online IIRC.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  6. #6 Re: Not sure what the true issue is.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I'm thinking the abs wire to hub bearing connectors are corroded. unplug them all and see if the contacts are clean on both connectors. Also if the weather seal is not intact it will set intermittent codes because it will move around and lose contact.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  7. #7 Re: Not sure what the true issue is.
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Man.... if we all got a quarter every time this same question was asked on this forum.
    "The DIC is being as jerk..... All possible BAD messages flashing... " LOL.
    What's with this issue on the 04+ cars? This is an often occurring problem. It should be part of regular maintenance like the LIM's. Jeeze
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  1. So much this man says is soo true.........
    By 16MustangVet in forum Off Topic Discussion
    Last Post: 11-18-2013, 05:29 AM
  2. Is this true?
    By Phlip77 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-20-2013, 07:06 PM
  3. is this true?
    By jerrysalley in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2010, 10:41 AM
  4. is it true??
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2009, 10:11 AM
  5. Is this true?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 09-26-2008, 07:50 PM
