Thread: How hard is it to remove the trailing brackets?
Results 1 to 7 of 7
  1. #1 How hard is it to remove the trailing brackets?
    Sep 2015
    Lansing, Michigan
    200k on body. Some rust on the brackets and mounts.
    Can I use just a ratchet? I have a breaker bar. Do these bolts have a tendency to snap off if they're really rusted? I have some pics that I can upload later.
  2. #2 Re: How hard is it to remove the trailing brackets?
    St. Louis
    I'd soak them in some penetrating fluid a few days beforehand. Other than that, when I went to install my new brackets for my GMPP arms they came out without much struggle. Did that with somewhere around 275K on them probably. Breaker bar to get started and just work them back and forth then ratchet to bring em out.
  3. #3 Re: How hard is it to remove the trailing brackets?
    Sep 2015
    Lansing, Michigan
    I just loosened all the bracket bolts while the car was on the ground with just a ratchet. They backed out with ease. I didn't even soak them with anything. I snugged them back up really tight.
  4. #4 Re: How hard is it to remove the trailing brackets?
    Nov 2012
    Madison
    I don't what year car you have but how many bolts were holding it to the body?
  5. #5 Re: How hard is it to remove the trailing brackets?
    Sep 2015
    Lansing, Michigan
    2002. There's 3 bolts on both brackets. 1 in front, 2 on back.
  6. #6 Re: How hard is it to remove the trailing brackets?
    Nov 2012
    Madison
    Quote Originally Posted by tom5170 View Post
    Thanks, my 04 was the same. Just did mine 2 weeks ago
  7. #7 Re: How hard is it to remove the trailing brackets?
    Sep 2015
    Lansing, Michigan
    It's also the same exact bracket on my 03 buick century with 3 bolts each.
  1. Working hard...or HARD at work
    Last Post: 05-03-2013, 01:19 PM
  2. Sparkplug wire hard to remove fix
    By JEFF WATSON in forum Introductions/Noob Questions
    Last Post: 03-31-2013, 07:06 PM
  3. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  4. Rusty Trailing Arm Brackets
    By harrydunn in forum Brakes/Suspension/Chassis
    Last Post: 04-24-2009, 11:33 AM
