Thread: 07 GXP crazy problem!!! Help!!!
Results 1 to 5 of 5
  1. #1 07 GXP crazy problem!!! Help!!!
    SE Level Member Allengator's Avatar
    Aug 2016
    Burleson, TX
    I thought I had a bad ignition switch... But a new one proved that wrong!!
    See video for more info!
    https://youtu.be/PhIX2AApc7I
    Bad BCM??? ECM????
    Allengator
    Burleson, TX
    2006 Grand Prix... aka the FREE GXP
    My band... www.OuttaTheBlueLive.com
  2. #2 Re: 07 GXP crazy problem!!! Help!!!
    I'd rule the PCM problem out because the engine starts and runs like normal.
    Possible BCM fault, you could try to pull codes on it and see if anything will show up.
    It wouldn't hurt to find all the power and grounds from the battery to fuse box and body and clean everything, make sure all contacts are free of corrosion.
  3. #3 Re: 07 GXP crazy problem!!! Help!!!
    Aug 2016
    Burleson, TX
    I will start cleaning things up...
    In the mean time I am hoping someone has seen this before!
    Allengator
    Burleson, TX
  4. #4 Re: 07 GXP crazy problem!!! Help!!!
    Aug 2016
    Burleson, TX
    so far, still no luck!
    Allengator
    Burleson, TX
  5. #5 Re: 07 GXP crazy problem!!! Help!!!
    GT Level Member primem's Avatar
    Sep 2013
    Calgary, Alberta
    i was wondering if you have a power mode mismatch. You will need a scan tool to confirm the power modes and to check for body dtcs
    2004 comp g
  1. Am I crazy?
    By twitticus in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2014, 10:49 PM
  2. Help going crazy!
    By cmccarty22 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-20-2013, 07:20 AM
  3. Crazy A/C problem(s)
    By Agentlongwood in forum General Tech Discussion
    Last Post: 07-06-2011, 02:57 PM
  4. i must be crazy
    By Toasty in forum General Tech Discussion
    Last Post: 03-20-2008, 08:03 AM
  5. crazy but possible......
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-16-2008, 08:42 PM
