Thread: P0446 code
Results 1 to 15 of 15
  1. #1 P0446 code
    GT Level Member willie14's Avatar
    Jun 2016
    westland mi
    So I just got this EVAP vent circuit control code but am having no issues with the car. I'm not tring to spend 200$ on a dealer part to fix this but doesn't this mean that it could just be clogged and needs to be cleaned out? Where should i start first?....
    98 Grand prix SE to GTP conversion( in works). Full body conversion in works, drilled n slotted rotors, ceramics, all new suspension, custom CAI, NGK wires/Vpower plugs, SD headers, 180 Tstat, AND A WHOLE BUNCH OF PAINT BABY!! Tuned by E&J performance.
  2. #2 Re: P0446 code
  3. #3 Re: P0446 code
    Jun 2016
    westland mi
    Yea I read up on it already, just curious as to what everyone else has done to fix it...
  4. #4 Re: P0446 code
    you follow what the codes says.
  5. #5 Re: P0446 code
    HUDSON
    I just replaced my vent valve with a new one from RockAuto, however you may be able to get by with just a cleaning. They tend to get filled with dirt and dust, there is a small foam filter inside that can get plugged up with dirt.
  6. #6 Re: P0446 code
    Jun 2016
    westland mi
    How much u pay for it?
  7. #7 Re: P0446 code
    HUDSON
    It was around $24, but before you buy any parts, make sure all the wiring has continuity, and all the connections are good.
  8. #8 Re: P0446 code
    Jun 2016
    westland mi
    I'm still NA for the time being. Is the vent valve directly behind the UIM or is it in the drive side fender?
  9. #9 Re: P0446 code
    vent valve is on top the canister under the gas filler neck.
  10. #10 Re: P0446 code
    Jun 2016
    westland mi
    Ight well I got monday off so ill try n see if I can figure it out then and update. So to be clear then its back under on the back side of my rear quarter panel? I can access it from underneath the trunk area or can I get to it from the trunk?
  11. #11 Re: P0446 code
    Apr 2016
    Maryland
    Lay behind your rear driver side tire and look up. Just take it out and clean the crap.out of the whole thing.
  12. #12 Re: P0446 code
    Jun 2016
    westland mi
    Ok no doubt. I'll update Monday...
  13. #13 Re: P0446 code
    Jun 2016
    westland mi
    So I know I was supposed to update, but I've been busy trin to prep all my body parts for the conversion to paint. Anyways its been a bit since I cleared the code and it hasn't come back yet so maybe I'm good? I never did get around to cleaning the vent valve yet but will do so soon. Good bye ugly old SE, HELLO custom JOB
  14. #14 Re: P0446 code
    Quincy, Mass
    It's can 2-300 miles for it set the code again. You might get lucky though and it might not come back for a few months.
    No more GP 04 Impala SS Indy:
  15. #15 Re: P0446 code
    Jun 2016
    westland mi
    Yea I mean I figured I prob wasn't in the clear completely, but I figured I was good enough for now to focus on something else. I'm trin to do like 50 different things on this car at the same time and with a limited budget now and my crazy work schedule as of lately I try n focus as much time as I can finishing the car
  1. hard to fill up gas tank and P0446 code
    By khornocker in forum General Grand Prix Discussion
    Last Post: 10-22-2016, 11:32 PM
  2. code P0446
    By vagk1234 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-01-2013, 10:08 PM
  3. P0446
    By gagt3100 in forum General Tech Discussion
    Last Post: 10-22-2012, 04:33 PM
  4. P0446
    Last Post: 10-06-2012, 01:24 AM
  5. p0446
    By roundbox52 in forum General Tech Discussion
    Last Post: 09-24-2010, 07:54 AM
