Thread: Need help with antifreeze leaking
Results 1 to 8 of 8
  1. #1 Need help with antifreeze leaking
    Jul 2010
    Canada
    I have a small amount of antifreeze leaking, it will take 3 days to leak out completely.
    I have replaced the thermostat (100K ago), Water Pump (5K ago), and just replaced the coolant elbows.
    The leak seams to be coming from the passenger side, in the back under the alternator (might not be where it is originating from but if you look underneath it drips below the alternator area)
    What else could this be?
    2004 grand prix gt
    360,000 kms
  2. #2 Re: Need help with antifreeze leaking
    check the heater hoses off the alt bracket.
  3. #3 Re: Need help with antifreeze leaking
    Jul 2010
    Canada
    I found out where it was dripping from, it is right on the firewall and it there isnt a hose attached to it or anything. It is just dripping once the car is warmed up
  4. #4 Re: Need help with antifreeze leaking
    so its a/c condensation? it will leak water on the pass side.
  5. #5 Re: Need help with antifreeze leaking
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    3 days to empty what? Just the overflow tank?
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  6. #6 Re: Need help with antifreeze leaking
    Jul 2010
    Canada
    It seems that the condenser is leaking quite a bit of water. My understanding is that the AC cannot leak coolant. There is now visable leaks other than from the Condenser which is leaking lots of liquid. Probably too much, other than that there is no leak. Hoses, water pump, coolant elbows, Thermostat, all seem good.
    Any other ideas on whats causing 2 liters of coolant gone in a couple of days.
  7. #7 Re: Need help with antifreeze leaking
    Jul 2010
    Canada
    3 days and half the coolant in the car is gone.
  8. #8 Re: Need help with antifreeze leaking
    so you got a hose leaking. heater hose, or the coolant tank hose, is the tank bone dry?
  1. Antifreeze leaking through floor boards
    By Drummer9103 in forum General Grand Prix Discussion
    Last Post: 07-04-2013, 10:01 PM
  2. "98 GP- 3.1L leaking antifreeze
    By Patrick551 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-26-2013, 05:37 PM
  3. Leaking Antifreeze?
    By Points70 in forum General Tech Discussion
    Last Post: 09-26-2011, 08:13 AM
  4. 04 leaking antifreeze?
    By MYGT2 in forum General Tech Discussion
    Last Post: 03-22-2011, 07:35 AM
  5. Leaking Antifreeze
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 08:13 PM
